Old 04-02-2005, 10:21 AM
HatTrick HatTrick is offline
Default New Yamaha 4 stroke numbers
Was it cold...yes, was the rain pelting me...yes, was trying out a new motor awesome...absolutely! My old 1986 merc 2 stroke must have been more tired than I thought, because the new 4 stroke, which isn't supposed to be so quick out of the hole, is a real rocket. The tide and wind were pretty strong but I think these numbers are good. I arrived at the speeds by comparing the GPS speed to the depthfinder speed and taking into account the direction of the current.
Motor: 2005 Yamaha 150 4 stroke 25 " leg (extended transom)
Boat: 1986 SeaCraft 20 ft CC (20'6")
Carrying: One person, 40 gals fuel
Prop: 14x19
2000 rpm 9 mph
2500 rpm 12 mph
3000 rpm 23 mph
I haven't gone above 3200 rpm as I am still breaking her in. Between 2500 rpm and 3000 rpm she leaps up on plane.
'86 20 ft CC with 4-stroke 150 yamaha
Old 04-02-2005, 10:39 AM
Mark Mark is offline
Default Re: New Yamaha 4 stroke numbers
When you have a chance, I'd be interested to hear what you get at 4000rpm - both speed and gph burn (flat water, no tide calculation: straight GPS numbers).
Old 04-02-2005, 02:01 PM
I didn't buy the fuel management gauges so I won't be able to nail down gph but the speed info will be no problem.
Old 04-02-2005, 05:50 PM
Mark - The Prop calculator should give you a pretty good idea.
http://www.rbbi.com/folders/prop/propcalc.htm
Yamaha 150 gear ratio = 2.0
Prop Pitch = 19
With a prop slip of = .149
3000 = 23.0 mph
4000 = 30.6 mph (prop slip 14.9%)
4000 = 32.4 mph (prop slip 10%)
Old 04-02-2005, 07:11 PM
Whoa! [img]/images/graemlins/shocked.gif[/img] That prop calc says that my slip is only 9%.
20' Seafari, '91 Mercury XR4 w/ large gearcase, 1.68 gear ratio & nosecone, 6150 rpm, 16.5"P PowerTech prop, at 52 mph on the GPS. [img]/images/graemlins/grin.gif[/img]
Old 04-04-2005, 09:28 AM
Abe's Rocket Abe's Rocket is offline
FRFrank.
What size motor is that? 200hp?
Abe's Rocket
1986 Seacraft 23CC
etec 250
Portland, Maine
Old 04-04-2005, 04:06 PM
SC204 SC204 is offline
Hat Trick,I have the same boat as yours that I just put a new Evinrude 25" 175 Ficht on last year.I get about 35 knots according to the GPS wide open with a lite load(fuel, people).Not sure the prop numbers offhand.
Old 04-04-2005, 07:48 PM
Bottomline,
My old motor was a 1986 Merc 150 black Max with a 15x17 aluminum prop and I would get 32 mph (gps) at 4500 - 5000 rpm with a 1/2 tank of fuel and two people on board. I don't know what I'll see at those rpm's with the new motor, but I'll let you know when the break in period is over. All I know is that the new motor is peppier at low rpm's.
Old 04-04-2005, 08:22 PM
sailcat sailcat is offline
14.5X19 ss rapter
4100rpm
35mph gps
2 people 70 gals fuel
Bob
72 20'CC
Old 04-07-2005, 07:57 AM
I went out yesterday to do some more break in on the new motor. Here are some more numbers:
Prop: 14x19
2000 rpm 9 mph
2500 rpm 12 mph
3000 rpm 23 mph
4000 rpm 32 mph
I was only able to get the motor to 4700 rpms at full throttle. That doesn't seem like I'm getting what I should. Do I have the right prop?
