Old 04-05-2005, 09:16 AM
Phan000 Phan000 is offline
Default Overheat buzzer malfunction?
I have a 1988 Evenrude 150hp. The overheat buzzer sounds when the motor is stone cold. Anyone have an idea as to what might cause this?
Old 04-05-2005, 09:40 AM
RogueAngler RogueAngler is offline
Default Re: Overheat buzzer malfunction?
My personal experience is that the buzzer is not malfunctioning but something else. Have it checked by your mechanic immediately. My brother burned up a perfectly good 150 because he thought the same thing. It could be something minor and you don't want to turn it into something major with the summer approaching.
Old 04-05-2005, 09:45 AM
Finster Finster is offline
I am thinking more in terms of your oil injection system.
http://lecharters.com
'76 23 SC CC I/O
'86 20 Aquasport 200
There's more but w/e
Old 04-05-2005, 11:43 AM
HatTrick HatTrick is offline
Is it a continuous buzz or an intermittent buzz? On my old merc it was continuous for overheating and intermittent for oil flow.
'86 20 ft CC with 4-stroke 150 yamaha
Old 04-05-2005, 12:14 PM
It is a continuous buzz. But it occurs when the key is turned 1/2 way even without starting the motor. I am not sure how the motor could overheat when it has sat for 2 days. THe wiring is pretty old and I am hoping it is a malfunction.
It is a 2 stroke and the oil is premixed with the fuel so I am noty sure how it could be an oil problem [img]/images/graemlins/confused.gif[/img]
Old 04-10-2005, 01:21 PM
edloh edloh is offline
try posting in
www.marineengine.com , there is a retired OMC technician that is very knowledgeble, his name is Joe R.
Old 04-10-2005, 05:11 PM
CaptScottNC CaptScottNC is offline
I don't know the most about outboards and there workings but when you turn the key halfway there is supposed to be a buzz from the engine horn jsut to let you know that the engine horn is working and connected. Now maybe there was some sort of short in this device aimed at letting you know the horn/buzzer still works?? These are my thoughts. Before this problem did the engine chirp, buzz or whatever very briefly as you fired it up and then was quiet? Best of luck!
Scott
Atlantic Beach, NC
1977 Sea Craft 23SF
250hp Suzie 4-stroke
