Old 04-25-2005, 09:52 PM
bigblockdock bigblockdock is offline
Default Mercury V6 Lower Unit Problem?
I recently purchased a used 97 Merc. 150 hp. I have some experience working on the older V6's from the early 90's and while putting a water pump in I noticed the drive shaft had some side play in it at the pump base. I did not notice any play in a 98 I had just done 2 weeks prior (V6 150 also)Called the dealer where I got the motor and the mech. said it was normal to have some play as the bearing under the pump is now inverted and becomes tight when the motor runs as the hypo. gears in the unit push the shaft "up" but he would check it out. He did and said all is well. I test ran the motor the other day out of water on the hose and when I put it in reverse it sounded as if the shifter clutch/dog wanted to get out of there. A friend who works on the newer mercs at another dealership came over and listened to the noise and said something is wrong with the unit and suggested the drive shaft was not rising up and the pinion nut was striking the shifter clutch/dog. Took the thing back to the dealer and the mech. listened to it and said it was because of the prop, a 19 mirage SS. Heavy props cause the newer units to make this noise as the gears mesh when there is no water back pressure. (running on a hose) News to me. He took the prop off and the noise was still there but much lower. Their Prop man came out and put an alum. prop on and the noise was still there but lower in tone. He said this was a common problem with the older mirage props w/o the newer nylon hub. News to Me.they changed the oil and said it was ok, no signs of the unit going south. The magnet had some fuzz on it after I had cleaned it the day before after I ran the motor having found some fuzz on it then. He suggested a smaller dia prop or alum prop would elimate the noise but the unit was good to go. My friend stills says something is wrong as the noise is excessive and I agree. The chatter noise is well above the exhaust running on the hose while the mirage is on the motor and in reverse. there is no noise in neutral and the cables are all adjusted correctly. We even disconnected the cables a shifted by hand and the noise was still there. The other 150 has a 17 mirage and I did not hear this noise when it ran. The noise is also there in forward also but on a lesser note. the mech said this is caused by there being less ratchet teeth for the shift clutch on reverse than forward. I have ran this motor for approx. 1 hr. there was no prop on the motor when I heard it run. I will test run the motor in the river asap and listen at the back of the boat. there is no slippage in the clutch/shifter in either gear if you try to turn the prop in gear when not running. prop shaft turns smooth as silk. Anyone else come across this problem or am I getting scammed. They won't tear it down so that would be on me.
1985 seacraft SF18 with 97 merc 150 EFI
1988 shadow bass with 200 Johnson GT
74 searay 240V with modified 351 Ford/Mercruiser.
One is not enough!
Old 04-29-2005, 11:52 PM
Default Re: Mercury V6 Lower Unit Problem?
I have recently investigated this isue further by contacting another dealer known to me. He advised that on the non rachet type lower units, (that is the lower units that you can not turn the prop either way left or right when not running and in gear), a large SS prop such as a mirage will make some noise when running in gear on a hose. (rattle or chatter) the noise is elimated when the unit is in the water because of the prop pushing against water. On a rachet type lower unit you can turn the prop by hand in the direction the prop turns in that gear and hear a loud click as the ratchet slips and the prop will not turn in the opposite direction when in gear and not running. If a ratchet type lower unit has a rattle or chatter while running in gear on a hose you may indeed have a problem. I do not have a rachet type lower unit so the noise I hear is normal and the unit should be WHew! Hope this will help someone. Butch
One is not enough!
Old 05-04-2005, 01:16 PM
gw204 gw204 is offline
Butch,
Yes, this has helped someone. A fellow-Marylander at that. [img]/images/graemlins/smile.gif[/img]
My '02 Merc. 150 makes the same noise when I run it on the hose and put it in gear, regardless if there's a SS or AL prop on it.
It worried me at first, but after 2 flawless seasons, I stopped thinking about it. [img]/images/graemlins/smile.gif[/img]
Tight lines!
P.S. What part of MD are you in? I'm down near Solomons.
Brian
1981 Mako 17
Old 05-13-2005, 01:07 PM
Brian, I'm on the eastern shore of Maryland in Pocomoke City bout two miles north of the Md/Va line. I use to live in Carroll County back in the eighty's and fished from the bay bridge down to your area. Now I fish out of Crisfield most of the time. I'm glad I helped someone out. It had me pretty worried for awhile. I had just bought the motor used and the first time I ran it on the hose I thought it was going to blow. When I took it back the first thing they did was take the prop off and most of the noise disappeared. Then they put an alum. prop on and you could hear it but not like when the SS prop was on. I still worried about it until another dealer explained the same thing to me about the noise. I've used it one time since then and had no problem. Do you do any fishing up there? I here some monster rock have been caught near you. Butch
One is not enough!
