Old 05-06-2005, 12:39 PM
Default Rod Rack
Looking for ideas to build a custom rod rack that will be mounted on the ceiling of my garage. Would like to piano hinge entire top (tip ends) to a frame, and then suspend the bottom (rod bases). Thinking of building a solid pine frame around all four sides, storing horizontally, and dropping down (opening) to about 45 degrees, with two lines or cables as stops. I was hoping this would all fit inside of my bimini, which is also suspended from the ceiling. Anyone have any ideas/plans or seen anything like this before?
Unfortunately, it is too late to prevent all of my 4/0 and 6/0 from twisting after years of leaning up against the wall.
My garage/BOATHOUSE has urethaned crown and chair rail throughout and this will make a nice addition, most importantly getting more STUFF off the floor. Thanks, Vezo, Part II.
Can you tell the Whaler Woodwork Tunnel is showing a little light? Have a good weekend. Mike.
