Old 05-15-2005, 08:43 PM
SEAFARI SEAFARI is offline
Default 1999 225 SUZUKI EFI Problem
Put the boat in today, motors not running right. I can't
get it past idle in gear , it will stall. I can get it to rev up a little in neutral, but at some point it wants to bog back down.
It ran fine till the middle of December, put some stabilizer
in the fuel and fogged the motor at the end of December.
Put a new Racor in this spring, I also looked at the filter
under the cowling and looked fine. I also unhooked the fuel
line at the motor and primed the bulb and seemed normal.
The only three things that come to mind are varnish/gum
in the EFI system(Maybe I didnt give the stabilizer
enough time to run into the motor),but never had a
problem before and varishing usually takes more than
5 months to happen.
The second thing is electrical, maybe the stator is
bad? I had a similar problem with a 175 Merc, but
not quite the same.
The last thing is the fuel pump?? I think Scott
from Viking will be of help here, but looking
for other input. [img]/images/graemlins/confused.gif[/img]
Rodney
Old 05-15-2005, 09:45 PM
Briguy Briguy is offline
Default Re: 1999 225 SUZUKI EFI Problem
Fogger usually fowls plugs. Try another set.
Capt. Brian
Old 05-18-2005, 10:59 PM
Ed Ed is offline
Hey Chris-
Definitely talk to Scott. He has religiously serviced my 225 Suzuki the last couple of years and it runs well. If I had to guess, I would check the following:
1) Trash filter
2) Fuel pumps! The screws holding mine down had worked themselves loose over the years and they just about fell off. If they are loose and you are sucking in air....it might cause a stall.
3) The other thing that comes to mind is the Racor filter. Is it the same as the last one you used??
Ed
