Old 07-05-2005, 04:48 PM
stevebrownell stevebrownell is offline
Default Thru-hull: bronze fitting, stainless fasteners?
Any issues with using stainless screws to mount a bronze garboard drain plug, or should I use bronze screws.
Boat is stored on a trailer exclusively.
Thanks.
19XX? 20' I/O
Old 07-09-2005, 12:23 AM
edloh edloh is offline
Default Re: Thru-hull: bronze fitting, stainless fasteners?
could get galvaniz corrosion between the stainless screw and the bronze fitting. also, some grades of stainless is prone to "cracking" in salt water
Old 07-09-2005, 07:25 PM
JW-Tex JW-Tex is offline
Get a stainless steel plug from gemlux. http://www.gemlux.com/gemproducts.ph...ch=5&curr_pg=4
I am going to get one eventually.
Old 07-11-2005, 11:25 AM
Thanks for the heads up on the stainless fitting - shoot, I shoulda, coulda checked Gemlux...nice stuff.
next time.
Went with bronze fitting and bronze screws, 5200 bed over epoxy and cabosil mix.
19XX? 20' I/O
