Old 07-19-2005, 06:37 PM
CDLongJr CDLongJr is offline
Default Need help with 1986 WA Cuddy
I have a box in the floor in front of the engines. I think it's a bait well. There's a pvc pipe in the stern of the box that looks like it has been broken off. There are no other holes in the box. I found a ball valve in the transom that drains, (fills ? ), the box. The po has installed a bilge pump with a hose to reach over the transom to pump the water out.
I'm trying to find out how the original plumbing was set up & tracker can't help. They referred me to you. We are restoring this boat & she's a real runner with twin 135 Mariners. Any help will be graetly appreciated.
E mail for photos of the box if that will help.
The Ole Fart
1986 23' Walkaround w/cuddy, Twin 135s
Old 07-19-2005, 08:07 PM
Default Re: Need help with 1986 WA Cuddy
[img]/images/graemlins/confused.gif[/img] [img]/images/graemlins/frown.gif[/img] Granted, the boat is 19 years old, but it's still the same company so you'd think they'd have the info. And Tracker/BPS wonders why they get bad press on the Internet.
There are a couple members with the same boat as you, so hopefully they can help you out.
Old 07-20-2005, 12:38 PM
Finster Finster is offline
Better be carefull Scott or you'll have the big bad Trackerman on your ass.... [img]/images/graemlins/crazy.gif[/img]
http://lecharters.com
'76 23 SC CC I/O
'86 20 Aquasport 200
There's more but w/e
Old 07-20-2005, 01:31 PM
Billybob Billybob is offline
[img]/images/graemlins/shocked.gif[/img]Wow, congrats to Jason, huh.
CSC has become Tracker's customer service historical archive records department!
Sorry, I can't help you with the setup - mine's different.
Old 07-24-2005, 08:51 PM
BigMike8o9 BigMike8o9 is offline
I have a 86 walkaround not a cuddy it has a smaller cabin but My box is back like that and I don't belive it had a system to fill just to drain like yours. I will not be using the box as I have a bait tank that will mount over it.
It may have been an ice box for fish or bait. I will cut mine out and close the second drain hole. It makes great access to my bait and washdown thru-holes. Also the back up builge pump will be right there.
Big Mike
mailto:bigmikeslures@aol.com
www.bigmikeslures.com
Old 07-25-2005, 06:47 AM
Thanks Mike.
Sounds like mine. I found out yesterday that the valve will fill & drain. The problem with filling is it keeps filling into the boat. The bilge pump quit & I had to make for the dock as the boat was taking on water. I have to find the correct way to plumb it or use it for an ice box.
The Ole Fart
Old 07-25-2005, 06:15 PM
I'm going to use the through hull after all.Don't know what I was thinking..To drain the new bait tank. Perfect location. I have move the new tank towards the bow and now have that great hatch left for the access. I have trimed the old tank out so that about an inch and a half of it are left to act as ribs for structural stiffness.
