Old 07-22-2005, 12:42 AM
gw204 gw204 is offline
Default 1985 Grady White 204 Fisherman Center Console
I know it's not a SeaCraft, but I'm sad just the same. [img]/images/graemlins/frown.gif[/img]
I thought I would be happy the day I got to post this ad, but that just not the case. I tried to do it last night, and just couldn't. She's my baby. She's my pride and joy. She's for sale.
1985 Grady-White 204 Fisherman Center Console
·Center Line Length: 20’4”
·Beam Amidships: 96”
·Transom Height: 25”
·Hull Draft: 14”
·Maximum HP: 230 h.p.
·Weight: 1995 lbs.
·Fuel Capacity: 80 gallons
·Custom T-Top installed 11/03 by Pipe Dreams Marine. Top has 4 rocket launchers, Taco Grand Slam outrigger bases and a small, 3 sided enclosure.
·Custom leaning post w/ storage and 4 rod holders installed 4/04 by Pipe Dreams Marine
·Custom made instrument panel w/ new Teleflex Blue Amega gauges and new illuminated rocker switches installed 3/03
·All teak replaced with maintenance-free Starboard
·New helm and steering cable installed 3/03
2002 Mercury 150 Saltwater
·Installed 3/03 with new binnacle control and throttle and shift cables
·215 hours
·15 x 17 AL 3-blade prop and 14 x 17 SS 3-blade prop (needs to be re-hubbed)
·Mercury Premium Plus oil, Yamaha Ringfree and Stabil used
·35-37 kts at 5800 rpm WOT w/ medium load
·All maintenance records are available
1982 EZ-Loader single axle roller trailer
·Complete (actuator, lines and drum backing plates) new brake system 4/05
·New bearings and seals 4/05. Bearings repacked 7/05.
·New tires 4/05
·New 50’ winch cable 7/05
·Spare tire and mount
Electronics
·Furuno LS-6000 w/ transom mount transducer w/ speed and temp
·Garmin GPS MAP 215 w Chesapeake and Delaware Bay charts
·Raytheon VHF and Shakespeare Centennial 5101 8’ antenna
·Navman fuel flow meter
Miscellaneous
·Bennett 12” x 12” hydraulic trim tabs
·Porta-Potti
·Raw Water Washdown
·Dual Batteries w/ switches and battery combiner mounted under console
·Swim Platform
·Dot-Line Gunwale Outrigger Mounts. Poles are included but have been modified to fit Taco bases on the T-Top.
·Tarp and PVC supporting frame for winter storage
She's on the market because it's time for us to move up. I tried and tried to figure out a way for me to keep her, but it's just not possible. Treat her right please....
$16,500 or best offer
gw204@hotmail.com
410-586-9190
Brian
1981 Mako 17
