Old 08-16-2005, 10:58 PM
benhardj benhardj is offline
Default 20' Seacraft Hull Weight
I am in the process of repowering a 20' slickcraft. I think the hull should be close in weight to a 20' seacraft. I was just wondering if anyone knew an approximate hull weight for the seacraft?
Old 08-16-2005, 11:17 PM
riffraff riffraff is offline
Default Re: 20' Seacraft Hull Weight
1600 # without the motor.
Old 08-17-2005, 12:22 AM
Default Re: 20' Slickcraft Hull Weight
If you have the Slickcraft 20' SS series (SS 205 or SS 215), the hull weight of the SS 205 open cuddy sterndrive model is 2105 lbs. The SS 215 is the same boat with a 270 lb fiberglass hardtop added on. Standard power for both was Mercruiser 188 hp V8 Fords. Optional power was 225 and 260 hp.
(I once sold new ones, coincidentally at the same time as we sold SeaCraft) [img]/images/graemlins/smile.gif[/img]
Old 08-17-2005, 10:14 AM
Mine is the center console model? It measures 19' 8". My uncle had the boat since it was only a few years old and told me it was set up for twins at the time.
Old 08-20-2005, 12:15 AM
I have to admit, we never sold a Slickcraft center console. I don't know what the hull weight would be. SInce the cuddy model was heavier than the SeaCraft, I can only surmise the same would be true for Center console. I would guess around 1800 lbs or so.
Anybody got a BUC book to check on this?
Old 08-30-2005, 06:52 PM
peterb peterb is offline
Go to the following web site and you should get an answer
web page
