Old 10-07-2005, 11:59 PM
edloh edloh is offline
Default Painting Seacraft 23'
will be painting the outside of my seacraft. what is the best way to
1. remove boat from trailer
2. type of stands to allow for painting on exterior (complete)
3. boat might be in water a few days once in a while. what is the most durable (scuff resistant) paint out there?
thanks for any input
Old 10-08-2005, 12:28 AM
Default Re: Painting Seacraft 23'
I was lucky enough to have access to an A frame and
a fork lift. Had two cables made to attach to the forks on
the lift. Only down side was painting on my back.
Sprayed with Awl Grip [/image]
Good Luck, Ken
Old 10-08-2005, 11:28 PM
kent,
i am assuming you attached the chain to the eyebolts at the transom. where did you attached the boat to up front?
Old 10-09-2005, 08:23 AM
Cables to the U bolts at transom, Lifting ring at the bow.
Here are a couple more pics.
Lifting ring at bow has 1/2 inch stainless threaded rod that ties into the bow eye. Do not try to lift boat with just a cleat. Bosun Supply or West Marine, etc. carries them.
Hope this helps.
See ya, Ken
[image]
