Old 12-02-2005, 01:11 AM
edloh edloh is offline
Default Trailer Size for 23' Sceptre
looking at getting a trailer for my 23'. from my calculation
hull = 2800 lbs
2 engines = 900 lbs (750 now)
fuel 100 gal = 700 lbs
misc = 200 lbs
total = 4600 lbs.
found a trailer that has a carrying capacity of 4600 lbs. am i cutting it close? any board member use a 4600lbs carrying , 5900lbs gross trailer ? thanks
Old 12-02-2005, 01:25 AM
lost2a6 lost2a6 is offline
Default Re: Trailer Size for 23' Sceptre
I think that you'll end up putting more than 200lbs of misc. gear in the boat. My Sceptre and my Seavette both weigh around 6300lbs with trailer, full of gas, gear, and beer [img]/images/graemlins/grin.gif[/img]. You'll need to go with at least a 7000lbs capacity to be on the safe side.
Steve B
Old 12-02-2005, 10:21 AM
RS RS is offline
I'd look into getting a ligher aluminum trailer. The same GVW will translate into more load capacity.
Best regards,
Roger
1979, 20' Master Angler
Old 12-02-2005, 02:11 PM
Lenny Lenny is offline
Didnt have a Sea Craft but my previous boat ( Hydra Sports ) was supposed to be 3500# with engines, so said the dealers handboook and I bought a 7000# GVW trailer after replacing the master cylinder and having to check the hubs "loose" several times in a short time I decided to weigh my rig at a scale full of fuel, no water, full electronics, survival suits, and onboard tackle storage draws filled the boat weighes 6980# [img]/images/graemlins/blush.gif[/img] [img]/images/graemlins/blush.gif[/img] I sold the trailer to a guy who put a 23 SC CC on it and I went with an 8600# GVW trailer. You could get by your whole life without incident but if you get into an accident with an undersized trailer the INS CO's are going to have you holding your ankles and praying for forgiveness while the plow you. Just my $.02 Be sure and do it right the first time
Under the knife 1969 20 CC I/O
Old 12-02-2005, 02:20 PM
BigMike8o9 BigMike8o9 is offline
Hi Guys, I got a "Baja style trailer" It's pretty much a copy of Florida trailer but way heavier. I went up a size because a bracket is in my future. It would fit a 26 ft boat and I think the GVW is around 8,000 lbs. I have a lot of space so I went wiyh a heavieand little longer tounge.
Upgraded all the lines and brakes.
It's from ABT the only Aluminum boat trailer maker on the west coast. I think it was arround 4k. But it's a monster.
Once I have the boat done I will transfer it to the new trailer and check tounge wieght %. To me thats the most important thing of all. The fuel and fishing supplys stored for a long trip are different after the trip. So I take the scale with me.
This may sound odd to you guys but often I travel over nasty mountain roads.
www.bigmikeslures.com
Old 12-02-2005, 03:59 PM
If you're talking about actually trailering down to Baja, yeah, having the trailer go out on that downhill approach to Santa Rosalia would SUCK! (as must be the opionion of all the truck drivers whose trucks are in the canyon below the road now [img]/images/graemlins/blush.gif[/img]).
Old 12-02-2005, 04:35 PM
ocuyler ocuyler is offline
I agree with want2fish that you should be 1 size up and buy a quality trailer with disk brakes and torsion axles.
Otto
Old 12-02-2005, 04:52 PM
nestorpr nestorpr is offline
If you don't want to spend too much on a new trailer, try a Continental, they're aluminum, work very well and are more affordable than some of the top brands. I'm very happy with mine, no problems at all in 2 years, we'll see what its longevity will be.
Boatless again!
Old 12-02-2005, 06:23 PM
edloh,
My father's Sceptre is about the same gross weight as yours, except he has a single 225 Yam 2S and carries 144 gal of fuel. He's got a 6000# GVWR trailer that seems to be up to the task. Granted, the trailer is used primarily for storage and only sees towing duties a few times a season for a grand total of 6-8 miles per trip. If you're towing all the time, you may want to step up to 6500-7000#.
want2fish,
Please don't mention the trailer you sold to Trayder's neighbor. It pains me to think about how I turned down the opportunity to buy it right before he did. [img]/images/graemlins/crazy.gif[/img] [img]/images/graemlins/grin.gif[/img]
Old 12-02-2005, 07:19 PM
warthog5 warthog5 is offline
I agree with the 7000GVW unit. My trailer weigh's 1030lbs, so that leaves you 5070lbs of boat and equipment.
You never want to push the limit's.
To me the foward keel bunk's are not an option. They are a necessity.
