Old 01-14-2006, 03:01 PM
dcobbett dcobbett is offline
Default Tank coffin + foam questions
Couple of questions for those that have done new decks or replaced the fuel tanks in their 70’s vintage SeaCrafts.
I removed the tank from my SeaCraft on 1/6/06, and the bottom of the containment area looked like this (see first photo).
On 1/13/06 it looked like this (second photo). It seems to have “dried out”, but there are still a few dark (wet?) spots, and the bottom of the foam still looks damp.
Is the moisture in the surface layer of glass, or under it, and what do I need to do to make sure the area is dry before I put a tank back in there and seal the area up? Also, it looks like the floor of the tank area is just glass; I don’t see a level piece of plywood; it looks like the space is bridge by layers of fabric and resin. Is that normal construction in these hulls?
Finally, the foam at the rear face of the tank area has 3” +/- dia shafts cast into the corners (see third photo). They run all the way back to the bilge at the rear of the hull. They have a smooth bore, but nothing in them. Are they “standard” for these hulls, what were they for, and should they be closed up? Also, looks like the foam under the decks at either end of the tank space has settled. Should I try and get new foam in there or leave the space for air circulation, etc.?
Old 01-14-2006, 03:41 PM
Scott Scott is offline
Default Re: Tank coffin + foam questions
I need to re-read your post but
This is my fuel deck … mind you in a 23
I thought my deck was fine too....
This is what I found after I took it out!!!
As for foam … in general it is ill advised to foam in the tank (I’m not sure if that’s how you plan to redo it). That moisture you talk about is the moisture that will, over time, destroy the tank. Unless the fuel cell is totally sealed foam can create problems.
I would thoroughly, methodically, painstakingly check that deck out before you drop a new tank in there
Old 01-15-2006, 01:34 AM
when I see dark areas I think rotton wood. My 75cc had a glassed over wood platform that the gas tank sat on. Most of the other guys have had the same set up on their boat. I'd look further for wood under that fiberglass. As for the holes in the foam I think they must have placed that in there for drainage. There was no foam around my tank and I would do away with the foam in the fuel compartment. There is pleanty of foam in the rest of the boat. Find another way to secure the fuel tank. Provide good ventilation for the fuel cell. Not a bad idea to coal tar epoxy the tank as well. Here are two links.
http://www.casdvm.com/photos/SeaCraf...ttery%20boxes/
http://www.casdvm.com/photos/Gas%20Tank%20Support/
Old 01-15-2006, 02:20 PM
Scott, Strick,
Thanks for the responses.
My initial reaction when I first saw the bottom of the coffin area was that there wasn’t a plywood deck in my hull. I could see what looked like the outline of the center stringer (see the top portion of my first photo), so I assumed the dark area was probably solid resin/glass. Are you guys thinking that the outer edges of the dark area may be the limits of the feathered edge of the ply deck? If so, I’ll drill some holes near the centerline to see what I actually have down there.
I’m pretty sure I will be getting a new tank. So far, I’ve talked to Kentfab (local, in my area) and Atlantic Coastal in NJ. AC is suggesting that I 5200 small patches of polyethylene to the bottom of the tank, foam the tank in only at the corners, and don’t use mechanical fasteners with welded angles along the top of the tank. Doesn’t seem like enough to hold the tank securely in place.
In an earlier post, I asked about the feasibility of adding bulkheads at either end of the tank coffin area; any comments on that idea?
Old 01-15-2006, 10:24 PM
I don’t think they would make a solid fiberglass deck but who knows … Are you sure its the outline of the stringer ? look at the photo , I have that too. That was from the neoprene that was under the tank … three strips the length of the tank. They left that line in the deck.
Not sure what you mean here . In our boats(23’s) the plywood core/deck went all the way to the box stringers. Glass was laid over the top and tabbed up the stringer. There were several layers in the transition from stringer to deck. That did give the deck a different look (heavier glass in the inside corner )
Another builder to consider is www.sptanks.com they have a link that suggests how to install a new tank. These guys are just north of AC tanks and build a good deal of tanks ( they build for many new boat manufacturers also) …many member here have their tanks.
After seeing what foam that was wet did to my tank, I personally don’t want any foam holding it in.
Bulkheads would work.
Old 01-16-2006, 12:36 AM
EVERGREEN EVERGREEN is offline
I am in the process of replacing my tank as well. This is some good information that I found on tank installation.
How to Install an Aluminum Fuel Tank
. . . . So you Don't Have to Do It Again
by David Pascoe
Many people blame aluminum as being a bad material for fuel tanks. Actually, its not. All materials have their strengths and weaknesses, and the problems with aluminum tanks are problems of proper installation, not the material itself. Properly installed, aluminum tanks will usually outlast the life of the boat.
Here's the answer that many of you asked for on how to install an aluminum fuel tank so that it doesn't corrode and leak again. Fuel tanks don't corrode because they get wet; they corrode because at some point something is in contact with the tank that traps water between it and the tank. Like the original foam that it was installed with. Aluminum is self-protecting, so long as the surface gets adequate air exposure. Severe corrosion is always caused by water plus a lack of oxygen. Metalurgically, this is known as "crevice corrosion," and the key is to eliminate all the points (crevices) that trap water. As long as the aluminum has a good air flow around all surfaces, contact with water will not damage it.
For replacing tanks foamed under the deck, between stringers, or tanks just sitting on a bare plywood deck, you need to build in a new deck. This can be done by thoroughly glassing over good quality plywood, being sure to thoroughly seal the edges of the plywood so it doesn't suck up water. Use mat if you like, but be sure that its completely wetted out, and use two layers for the top surface. Its best to glass the edges in a second operation, after the two surfaces have been done. Wait until the resin kicks off before doing the final roll out.
Note: You may need to add frames under the deck so that it doesn't sag, depending on the amount of the span between stringers. If the tank is more than two feet wide, we'd recommend this. Install the frames before glassing. Also, if it looks like the deck is going to collect water in the center, its a good idea to drill a few 1/2" drain holes, coating them with resin or epoxy so they don't rot.
The best method for mounting the deck is to fasten heavy, fir ledger strips to the side of the stringers. Make sure the height of the ledge strips is tall enough that they are not going to split. Its probably best to cross bolt through the stringers rather than using screws, if possible. Remember that this has to withstand the weight of the fuel with the boat slamming, so you need to make them strong. Then heavily fiberglass or epoxy the ledger strips (before installing) so they don't rot and set the fully glassed deck on top. Counter sink your deck attachment screw holes about 1/4" and then fill the counter sinks with epoxy or 5200 after the screws are set.
As shown in the illustration below, you are going to set the tank on top of 1/4" strips of plastic about 2" wide and spaced about every 12". Its best to place the strips transversly to the length of the tank. We recommend Haysite or any of the fiber reinforced plastic sheet. The strips should be cut to a length exactly 1/4" shorter than the width of the tank. We don't want the strips sticking out the sides and collecting water.
Next, you will need at least two tubes of 3M 5200 adhesive, and you will literally glue the plastic strips to the bottom of the tank. Apply the adhesive so that the entire surface of the plastic is coated with 5200 and will not leave any gaps or crevices for water to get into. Once the strips are pressed into position, make sure that the ends are equally 1/8' from the edges of the tank. Wipe off the excess 5200 that squeezes out, making sure that the joint between tank and plastic strip is completely sealed. Don't leave any globs of material.
Allow 24 hours for the 5200 to set up before setting the tank in place. Next, apply two 1/4" wide beads (like a stream of tooth paste) of 5200 along the length of each plastic strips that are now glued to the bottom of the tank. The strips do not get fully bedded because tanks expand and contract as they are filled and emptied. If the bottom distorts, we want the plastic strips to loosen from the deck, not the bottom of the tank. If the later happened, we'd be back to our crevice problems again. So we want just enough 5200 on the bottom of the strips to create some suction to hold the tank in place.
It will take two people to carefully set the tank straight down into place. You don't want to have to move or adjust its position once you set it down. Use wood shims on the inside of the stringers if necessary to guide it into the right position, shims that will be removed after its in place. The 5200 is so strong and will create so much suction that you not need any other method of securement. Don't worry that ballooning of the tank will break the seal. The weight of the fuel in the tank will pretty much hold the tank in place.
That's it! Now it won't matter if the tank gets wet because there are no crevices to trap water and cause crevice corrosion.
There will be situations where this method will have to be modified. Aluminum tanks are not expensive, so if you need to make modifications to the original shape, be prepared to do so. Just remember that the objective is to avoid creating points that create crevices and trap water. Here are few other points to consider;
· Never allow water absorbent material such as wood to come in contact with the tank.
· Do not use rubber strips: rubber contains carbon, which is cathodic to aluminum and will cause galvanic corrosion.
· It is best to use only stainless steel pipe fittings for the fuel supply. Do not mix a variety of metals. Do not use steel or galvanized.
· Make sure that wherever the tank is sitting on is a stable surface; always use the hull stringers and never the bottom of the hull.
· Make sure that straps or whatever securing devices you use don't cause crevice corrosion.
· Tank should not be so deep in bilge that its going to be in constant contact with bilge water.
Egreen
________________________
1985 23-SF
Twin Yamaha 130
Old 01-16-2006, 09:48 AM
Scott, EGreen,
Thanks. I'll let you know what I do and how I make out. I'm working outdoors and the weather has turned (wind chill factor last night was <-15^!), so I might not get back to the project for a few days.
