Old 01-20-2006, 02:42 PM
GradySailfish GradySailfish is offline
Default Bracket on a 20 Master Angler
On the rebuild pages, I see that all of the 20's are not bracketed boats, instead the owners rebuild the existing transom and maybe add 5 inches.
Are there any owners who can comment on stats pre and post bracket. I see mot of the 23 owners do replace thier "open" transoms with closed transoms and brackets.
Any suggestions/comments welcome.
2002 26 Fortier Yanmar 250 6LP-DTE
1978 20 Sea Craft Master Angler 08' 150 ETEC
Old 01-20-2006, 02:51 PM
Trayder Trayder is offline
Velvet Jones
Default Re: Bracket on a 20 Master Angler
Grady-
welcome to the site.
I have a 20 and was planning on putting a bracket on her but due to the size of the bracket my boat would no longer fit in the garage.
I also am not a fan of the aesthetics of the 20 with a bracket. The bracket is overpowering size wise. According to Bill Potter who brakceted his 20 overnighter the performace is improved speed and efficiency wise with his seamark bracket.
do a search on the site as this topic comes up frequently.
welcome aboard
Old 01-20-2006, 03:36 PM
Thanks for the reply. I didn't know who you were until I was told! You have the nicest picture documentary around.
Maybe I won't use an Seamark bracket, instead maybe a armstrong or stainless marine bracket. If the Seamark is soo big why not go with another brand.
My main reason I want the bracket is so that the transom of my boat will be higher in the water, and so that the transom itself will be totally closed, which would add a significant degree of safety.
I still have time to research before I make my decision.
I used the search function, but it's odd how it works....too many irrelevant hits!
Old 01-20-2006, 04:20 PM
Velvet Jones
Grady- Thanks for the kind words but I should be smacked for missing some key photos towards the end of my project. After 2 years I had enough and had to finish it so I worked hard but realled slacked off in regards to keeping the photyo journal. I klnow I have more pics somewhere but I have given up looking and now enjoy using the boat.
here are some relevant threads for you
20" transom options on a 20' boat
196920 with barcket photo essay
Raising transom to 25"
consensus on installing a bracket on a 20 CC
Enclosed transom / Transom mount
Pros' Cons of Engine Brackets
there is a tom more too
Old 01-20-2006, 05:32 PM
Thanks Tayder. I appreciate the info. Your boat came out beautiful, not only aesthetically, but the plumibng electrical, and other stuff that one normally "does not see" was also done with excellence. Thats the true mark of a craftsman.
I think I'll go against the bracket. I'll raise the transom 5 inches and engineer a clever new motorwell splash guard.
I'd like to see pics of how you finished off the stern section of your boat, espeically the motor well area.
Thanks guys, I promise you all a great picture gallery.
Old 01-20-2006, 05:37 PM
Oh two more questions, do all the 20's have trouble with water coming back through the stern scuppers? I've read of some people rasing the floors on thier 20's to avoid this, but I'm also inclined to think that these are the 20's that run bracketed outboards.
Sorry for all the questions, I'm a long time fisherman, but new to the Sea Craft family! I always knew they were great boats, just didn't know much about thier particularities.
Second question: Is the deadrise at transom 24 degrees? I know these boats ride well, just wondering how well.
Old 01-20-2006, 05:53 PM
Velvet Jones
Grady-
The boat is under wraps right now so Pics of my stern section will have to wait but here is a link to Mark's 20, his makes mine look like a wreck: Mark's 20
I do not think the Master Angler suffers from the same "wet feet" syndrome as the Superfish 20, Roger St. or Capt. Brad should be able to fill you in there they own 20 MA's
As for deadrise the 20's are only 17 degrees. It is not the deadrise that gives SeaCrafts the great ride it is their infamous Variable Deadrise. Check out the logo in the uper left hand side of this page for an exaggerated image of how the hull works .
or see here:
The SeaCraft Variable Deadrise
other hull's
Old 01-22-2006, 11:51 AM
RS RS is offline
On my MA, the scuppers exit from the transom. I solved the wet feet issue with ball scuppers.
Regarding a bracket on an MA, I don't think the "notched transom safety issue" is a big deal. A simple board allows a splashwell to be created which contains the errant wave that makes it over the transom.
Best regards,
Roger
1979, 20' Master Angler
Old 01-22-2006, 02:14 PM
A bit of an overstatement don't you think?!
Old 01-22-2006, 06:47 PM
Roger your boat looks good...even if I only see the stern area.
I'm glad the ball scuppers resolved the "wetfeet issue" Do you have anymore pics of your boat or the process involved in taking it apart.? If so I'd like to see them.
I looked at the boat again today and it appears to have a solid both, floor and transom. It's hard to believe but my 210 pound arse jumping up and down on the deck and hanging on the old "rude" of the transom didn't really make it move much. The only thing I saw that worried me were rust stains where the back eye rings go. Could it be possible a 78' hull has solid transom?
Yes Trayder, your boat is indeed a "wreck" you should be ashamed of yourself for slapping together such a hunk.
