Old 01-27-2006, 03:03 PM
Mooncusser Mooncusser is offline
Default Gel Coating Vinyl Ester
Does anyone know for certain whether gel coat will form a chemical bond to Vinyl Ester?
Old 01-27-2006, 03:37 PM
Scott Scott is offline
Default Re: Gel Coating Vinyl Ester
Vinylester is just a more resilient, and a bit more water resistant form of polyester resin. A lot of builders …I think even SeaCraft …. Use it today
Isothalic(sp?) based gel coat is what I have used in the past over vinylester (Isothalic is just a higher grade of poly resin)
They even make a vinylester based gel coat for high wear areas like a hull bottom. Vinyl is a step above Iso ...and cost more too.. Remember the gelcoats are really just pigmented resins.
Old 01-27-2006, 03:38 PM
Trayder Trayder is offline
Velvet Jones
It depends if cured or not-
Vinylester resins utilize a polyester resin type of cross-linking molecules and if applied "wet to wet" on poly gelcoat it will chemically bond. (like in a mold)
If you are doing a repair with vinylester resin, you should use laminating resin. Laminating resin stays tackyas it will not fully cure when exposed to air, this will allow you to get a chemical bond between the final layer of gel coat with wax or gel coat covered by PVA.
If the vinylester resin has cured, rough it up and shoot your gel-coat, the mechanical bond will be more than suitable.
Old 01-27-2006, 03:40 PM
Velvet Jones
oops
looks like Scott posted while I was typing.
Scotts nails the point, gel-coat is a tinted resin.
Old 01-27-2006, 03:54 PM
Fletch Fletch is offline
It has been working just fine for me. No problems at all...
