Old 03-14-2006, 08:36 PM
Guest
Posts: n/a
Default rod storage
My '78 23 cc seacraft's previous owner for some reason removed the wood rod storage pieces under the gunnels and threw them away, so I have no pattern to build new ones and they provide much needed support to the gunnel. Just wondering if anyone may have any old ones or a pattern for me to use to make duplicates. I am planning to make the new ones out of starboard and can make them with no pattern but would really reduce the cutting and trimming if I could come up with a pattern.
Thanks, Scott
Old 03-15-2006, 08:55 AM
stoney stoney is offline
Default Re: rod storage
You can have my old wooden ones if you want them. I have a 1971 23cc. If you are going to make new ones out of starboard make sure you use the 3/4" thick.
73 23 SF 2004 200 HP Yami OX66 Best boat I owned!
2002 29 Seavee twin 200 yami's
Old 03-15-2006, 09:05 AM
hermco hermco is offline
You can easily make a pattern out of cardboard trimmed to fit with a razor knife and then transfer to the material you are making the supports out of.
Old 03-15-2006, 09:06 PM
paulfurnari paulfurnari is offline
I had a pair made last year from 3/4" seafoam starboard for $350. They're still waiting to be installed. On the list for this Spring.-PF
Old 03-15-2006, 09:36 PM
Stoney, you say you have a '71 23' CC. I may be wrong, but I think you have a very rare SeaCraft. Could you give some info and post some pictures in the Photo forum.-PF
Old 03-20-2006, 09:00 AM
Rare indeed!!
There is no hull ID number in the hull. There is an embossed aluminum tag on the underside of the wood cover for the glovebox. The boat rides like a dream but appears to be a long project to get to the beautiful point.
I have done the transom and installed a new low budgetmotor due to cash flow problems (kid in private college).
http://i15.photobucket.com/albums/a3...repair5_15.jpg
Old 03-21-2006, 08:59 PM
Most of the classics start out about the same. Take your time, do what you can and do it right. I believe you have the only '71 23' CC on the web site, it's even an outboard. Has it always been an outboard or did you switch from IO. It truly is a classic!-PF
Old 03-22-2006, 03:47 PM
thedink9 thedink9 is offline
Scott
Have you considered replacing with either Taco or Lee rod holders? Check out pictures of Capt. Chuck's boat, for an idea of what they would like. They would screw into the face of the side gunnel that the original holders mounted to. Since you are not replacing with teak, I believe this is a better way to go and may be cheaper in the long run. A pair of Lee's run about 12-14 bucks. Taco's in stainless are a bit more. Dink
Old 03-22-2006, 08:58 PM
Guest
Posts: n/a
I have a little flex in the top of the gunnel. thats the main reason I am interested in putting them back on the boat I'm not shure but from looking at the boat it appears that the rod holders give support to the gunnels to reduce the flex. I actually already have sufficient rod storage, just trying to reduce the flex in the gunnels.
Old 03-22-2006, 09:30 PM
Scott, I've seen brackets placed under the gunnels the same depth as the rod racks to add support. Some people have removed the rod racks in the bow and the gunnel will flex without something under there. It doesn't look bad either. I've seen them made out of teak, made out of starboard you wouldn't notice them at all.
PS- sorry for hijacking your thread.-PF
