Old 04-26-2006, 09:53 AM
MM33 MM33 is offline
Default Starboard gauge backing on the center console
Thinking about putting Starboard up on the center console to mount all the Gauges, GPS, etc to. Anyone know what thickness sheet I should get for the job.
I am taking down that ugly teak border and Plexiglas sliding doors.
Anyone have any pictures to post that did a similar job?
Not sure what color either, white or black.
Thx,
MM
Old 04-26-2006, 11:51 AM
Bryan A. Bryan A. is offline
Default Re: Starboard gauge backing on the center console
I am in the process of doing the same thing. I am using Dark lexan that is 3/8" thick. It is a piece that someone gave me so I don't know cost or supplier but it may give you an idea of how it will look. I shaped the piece then wet sanded and buffed the edges. I cut the guage holes this morning. I will try to get some pics in the next few days, here is an old one.
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
Old 04-26-2006, 01:28 PM
That looks sweet, I was thinking of doing white, but black looks great. nice job.
Thx,
MM
Old 04-26-2006, 06:41 PM
i used 3/8 on mine and found it to be too thin (starboard) I ended up going with 1/2" and it works well- no flex with heavier electronics. Here are a couple of pix. Ive since added a black vhf over on the left hand side and putting a black am/fm over there as well. good luck- be sure to save your old one as a template for both the beveled edge and also the screw holes work well too. craig
you will probably find like me that ended up using all new gages, rewired the whole thing (which led to rewiring the whole boat)so beware- before it all ends it is possible to start getting real expensive!!!
Old 04-26-2006, 07:00 PM
Sleeto Sleeto is offline
I used 1/4" - no problem so far (1 year)
Old 04-26-2006, 09:28 PM
Nice job guys. Not to hijack the thread but question on guage backing material. How are you guys sealing the starboard against the console so it does not leak? I was thinking of taping off the area where I wanted a gasket to be then putting on a thin layer of black 5200, pull the tape and let that dry. This way I could remove the panel at any time and not have to re caulk. I guess that would not work on starboard but the 52 should stick to my lexan. Any thoughts or options. Thanks in advance.
Parker 2530 DVEC
Old 04-27-2006, 02:15 PM
stoney stoney is offline
I used 1/2" white. It is thick enough to allowed me to drill and screw the board to the console from the back. hidden screws made it look better to me. You can also 4200 it from the back and have no sealant showing.
73 23 SF 2004 200 HP Yami OX66 Best boat I owned!
2002 29 Seavee twin 200 yami's
Old 05-02-2006, 08:20 AM
pictures from console rehab! experimenting with a site that I can look at from work. new console
http://www.myfishingpictures.com/img/095636.jpg
old console
http://www.myfishingpictures.com/img/095635.jpg
