Old 05-16-2006, 07:24 PM
Default NEED HELP WITH FLOOR DRAIN REPAIR!
i finally think i isolated the leak into my bilge. it seems to be coming from the port side floor drain. so i want to replace both sides. i need as much detail and information available on how to do this. or if anyone in kendall area wants to get a little extra cash on the side and help me with it thats welcomed also. i dont wanna take my boat out again until i get it straightened out. please help if u can. my seacraft surely will appreciate it!
thanks
evan
Old 05-16-2006, 08:15 PM
Default Re: NEED HELP WITH FLOOR DRAIN REPAIR!
hey evan, welcome- just do a search on scuppers within the last year and you will get a ton of hits- lots of discussions on this subject- good luck- pretty straightforward and not to difficult to repair /replace- craig
Old 05-18-2006, 10:59 PM
time permitting i did some more inspection on my drain liner. it feels smooth inside of it with no deterioration apparent. but on the bottom of the boat it does not feel that good. seems like i can get a finger nail inbetween the hull and the tube. was thinking thats where the water comes in. any other ideas on this problem?
Old 05-18-2006, 11:36 PM
Scott Scott is offline
They need to be replaced
If you're talking about the brass thru hulls for the deck drain/scuppers ... the tubes are probably corroded and letting water seep into the hull. They need to be removed, area dried, and new tubes put in. In the case of a 23 hull, atleast, these tubes are mounted in a block of wood ... so they need to be dried after removal of the old.
Old 05-19-2006, 12:36 AM
scott, my boat is a 20 SF. i did another little test tonite. i put a plug in the bottom of the brass tube and poured water in the drain past the top almost level with the deck. opened the rear hatch and watched. could slowly see water running into the bilge from the bottom. previous owner had already tried to repair this by putting what looks like thickened epoxy down there.. looks sloppy. so i think i will remove the old tubes, let the wood or fiberglass (not sure what they are mounted in) dry and fill with epoxy and redrill for new tubes. i hope this is as easy as u guys make it sound.
Old 05-21-2006, 04:55 PM
i decided im going to let the surrounding wood dry out for this week while im out of town. when i come back just going to lather the brass tube in marine tex or 4200 and stick it back in the hole. im hoping the easiest way is the best way.
