Old 06-27-2006, 10:37 AM
pcfishslayer pcfishslayer is offline
Default New Deck Question ?
I bought a 20' CC from fellow CSC member Luis. I am in the process of replaceing the deck. I have the deck cut out. I was hoping to find out if it is best to sand the gel coat down to the glass on were the old meets the new. I was told that would provide a better bond. Could some one tell me if that is true. Any other words of advice would from others that have already done this would be appreciated.
Old 06-27-2006, 11:20 AM
Tarpinmon Tarpinmon is offline
Default Re: New Deck Question ?
Who ever told you that is right. Definitly plan on doing some grinding to get the best adhesion for the glass work. for the old to the new just make it as poress as possible 24 -50 grit on a grinder works nice.
Old 06-27-2006, 11:49 AM
Make sure you grind at least 4 inches into the area you
are going to lay the glass on to. This way you can fair
it out better. Raw glass has the best bond when clean.
Wipe with Acetone after washing the ground area.
Polyester or Epoxy resin is your next decission.
Good Luck!
See ya, Ken
Old 06-27-2006, 02:19 PM
but don't grind too far into the glass mat.. you lose 50% of the strenght of the old work
Don Battin
Pipe Dreams Marine
"Design her right,
Build’er well
Bend the throttles,
And let’er eat…."
Carl Moesly
Old 06-28-2006, 05:51 PM
I really appreciate the feed back. Thanks. I will post pictures as I go.
Old 07-07-2006, 01:32 PM
kwluis kwluis is offline
How about them pics?
www.coolseasfishing.com
2005 Sea Craft 23
