Old 07-09-2006, 09:54 AM
Default VHF antenna installation
OK - I've been living off my handheld, remnant from my last boat, and decided to get a fixed mount unit for my Seafari. I had the boatyard do the install on my last boat, and don't remember how it was layed out, or know if they cut the cable to length.
What is the general consensus on installing the antenna, where there is excess length of cable ?
1 - Cut to length to fit
2 - don't cut, coil the excess
3 - don't cut, stow the excess loosely / random
4 - other
Appreciate your wisdom
thanks
Bill
Old 07-09-2006, 10:12 AM
RS RS is offline
Default Re: VHF antenna installation
Cut to fit. Fewer problems from interference. Also, unlike other types of 2 way radios there is no significant difference in "tuning" from cutting the cable.
Best regards,
Roger
1979, 20' Master Angler
Old 07-09-2006, 10:41 AM
Old Blues
I agree with Roger. Even thou the VHF cable can be spliced, I think I would coil up the access just in case you change the mounting position at a later date and need more cable (Like up on a T-Top / Arch etc.)
Old 07-09-2006, 10:12 PM
Bryan A. Bryan A. is offline
I was always taught to avoid cutting if possible, Blue Seas cable seals are good for this. And take the excess and store or zip ty it so it lays against itself in straigh lines. No crossing or coiling of the cable for optimum performance. Anyone else do the same? Mine is setup this way but I have no comparison to see if it improves or not.
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
Old 07-09-2006, 11:16 PM
i left my excess coiled up under my console. have had no problems with the radio as of yet.
-evan
Old 07-10-2006, 12:29 PM
im a #2- i coil mine up as well- i do try to keep it away from the coiled up gps cable and the coiled up radar coil and the coiled up transducer cable(s)
Old 07-11-2006, 12:35 AM
Contact Jim at BOE marine and order a Digital brand VHF antenna with your custom length. They charge ~$10 to cut/new connector and with their small machanical connectors they are easy to get through tight spaces.
There may be a few weeks delay and there is a 5' min length.
I went the Digital route with only needing 5' and very happy!
- Nick
Old 07-11-2006, 01:09 AM
Fishjack Fishjack is offline
According to the instrucions from the Shakespeare Galaxy instructions -
"Route the cable to your transceiver, keeping it as far as possible from other electrical equipment and cables. The 50-ohm coaxial cable should remain at least 3 feet in length, measured from the point where the cable exits the antenna."
My radio is mounted in my electronics box on the t-top with the antenna just a few feet away - did not want the extra slack coiled behind my other electronics so the 3ft minimum worked out perfect.
1977 23' Superfish
ST250x Yam
Old 07-11-2006, 09:13 AM
RS RS is offline
I just wish I could get rid of the bazillion feet of transducer cable left over in the console. Between the vhf, sonar, gps, navman, lenco tabs, trolling motors, stealth charger and assorted other "normal" wiring and cables, every little bit of cleanup helps on my boat.
Best regards,
Roger
Old 07-12-2006, 11:33 AM
Thanks, all for the input. Got the install done, Uniden radio into a Shakespeare 8300 on a ratchet mount, on the side of the cuddy, port side, aft of the cabin window. Brought the cable in thru the cap, adjacent to the mount, under the gunnel and forward, then thru the bulkhead into the cuddy, up and over the cuddy door, across the inside of the starboard bulkhead, down, and back out thru the bulkhead, to connect to the radio, mounted vertically on the bulhead, under the helm. That actually used up most of the original length of wire, so did trim a little to install the connector, but not much.
Cap'n Chuck - you are a mind reader - how did you know I have ultimate designs on a hardtop, something like CSN's ???
after completion, turned it on, just to check receipt, on the weather channels - nice and clear. Proof will be in the pudding this weekend!!!
thanks all
Bill
