Old 07-15-2006, 02:07 PM
abl1111 abl1111 is offline
Default Ladder building material
I want to build a small ladder for my 23' Tsunami - it allows you to go from the cabin to the bow - quickly. I have the original ladder that is made out of a really light-weight moulded plastic ( mine cracked in a really b*tchy spot that cannot be replaced )
I want to copy the original design because it allows the ladder to hinge/swivel closed on itself and stow easier than a fixed style.
The question: What is a really lightweight material that is strong, maintenance freeand easy to work with ? i.e. the properties of wood, but lighter ? Starboard might not have the needed strength to hold bolts laterally...
Thx
Old 07-15-2006, 05:57 PM
Default Re: Ladder building material
Mine broke also, starboard I think would be best to try
Old 07-15-2006, 08:47 PM
Alan
This might be a first but I bet that waterproof composite decking material you get at Home Depot would work. I think it is called Trex The thickness is 5/4 which finishes at 1". It can be shaped with standard wood working tools like starboard. Also some planks can be purchased that are "grooved" for steps and I bet it's cheaper also
Old 07-15-2006, 10:46 PM
abl111, when you are through building your new ladder,
please let me know. I will buy it from you and/or make a
donation to this great site, and pay for the shipping.
My Secptre was stripped of all this stuff and I need a template.
Thanks, Ken
Old 07-17-2006, 06:02 PM
Make one out of fiberglass.
Old 07-17-2006, 07:19 PM
RS RS is offline
Thx
Starboard and trex are about 3x the weight of wood. I think the closest thing you'll find to what you want is ... wood.
Best regards,
Roger
1979, 20' Master Angler
Old 07-17-2006, 07:59 PM
I agree, wood is the lighest I can think of. Fiberglass sounds like too much hassle to build - it would be a lot of layup to make something that would need strength in every direction.
I was hoping one of you guys knew of some great 'stuff' that met the criteria.
I am still open for ideas though.
The original ladder was perfect - however not great quality. It looks like a it was a moulded pastic but there are a lot of voids in key areas (that's why my ladder failed, at least ). But, the design is perfect.
Old 07-18-2006, 06:53 PM
jongolds jongolds is offline
I'd love to see what it looked like and how it stored as well. Mine also was stripped of this.
In the meantime, I was going to try an build some sort of ladder early this year but I've found that with the plywood panels that I put in to fill in the v-berth, it's not a bad step up to get on to the bow anyway. It's not great mind you but it wasn't bad enough to put that much work in to.
The best I could think of before I'd abandonded my ladder idea was PVC tubing but, I was told it wouldn't last if exposed to UV rays from the sun so then I thought of metal wire conduit..which of course would rust. Maybe those ideas can help get you somewhere though.
1973 23' Tsunami, 300hp Etec
Norwalk, CT
Old 07-19-2006, 12:13 PM
RS RS is offline
Maybe you can rework part of an old/cheap extension or step ladder made of aluminum.
Best regards,
Roger
Old 07-19-2006, 05:14 PM
Its the folding aspect you have to consider, if it doesn't fold up like the original it would be a pain to store, that decking stuff would work as well I bet a bunch cheaper.
