Old 08-12-2006, 09:05 AM
rcnight rcnight is offline
Default Transponder
Any thoughts on transponder placement - in or out of the hull. My first SeaCraft was mounted inside and seemed to work fine. I like the idea of eliminating snag points off the rear.
Old 08-12-2006, 11:44 PM
jayded1 jayded1 is offline
Default Re: Transponder
Sorry,
Do you mean a transducer or are you talkin about an EPIRB?
Jayded1
20ft '79 Regal CC w/ 00' 225 Opti (PROJECT)
Bermuda
Old 08-13-2006, 12:43 AM
mine is in the bilge, held in place with a bit of 4200 as recommended by another forum member here and it works great.
Old 08-13-2006, 01:21 AM
The deadrise will alter the reading, best is thru hull then transom, it has to shot staight down to be correct
Old 08-13-2006, 06:28 PM
After filling three holes from old trans....ers, I decided to give the transom-mount ducer a go as a shoot through. I am trying my hardest to keep the transom pristine-even though I want a swim ladder, tabs, I just haven't brought myself to drill it yet.
Anyway, I made a sort of dam in the bilge and filled it with clear lifeseal and then slowly sank(trying to avoid air bubbles) the ducer into it, trying to eliminate some of the deadrise angle by keeping it horizontally oriented.
The thing reads beautifully-was marking all kinds of bait this morning in 60feet of water and bluefish all stacked up through the water column. I had heard I would lose resolution, but the thing looks at least as good as it does in simulator mode. It's worth a try and is a low risk install-you just lose the temp and speed-I didn't mind.
Old 08-13-2006, 07:25 PM
warthog5 warthog5 is offline
Then talk to Jim @ ByOwner about a tilted element X-ducer.
http://www.byownerelectronics.com/st...cat=492&page=1
http://www.classicmako.com/forum/top...chTerms=Tilted,Element,X-ducer
