Old 08-13-2006, 07:41 PM
WillyC WillyC is offline
Default rub rail installlation
Anybody know the approximate spacing for the screws when mounting the rub rail to the boat. This week I plan on thru-bolting the cap to hull joint with 4 inches between each thru-bolt. Then when its time to mount the rub rail, screw it to the boat with 4 inches between each screw having them fall half way between each thru-bolt. This would mean two inches between the thru-bolts and the screws. What do you think?
