Old 11-01-2006, 10:24 AM
classictrade2 classictrade2 is offline
Default Electrical problem
Last night when I was going over my 1976 Seacraft 23' inboard I noticed a problem. I looked at my alternator and found the jumper wire going from the main lead post to the top of the alternator was completely corroded and broken off. I also checked the main lead coming from the battery positive side directly to the main terminal on the alternator that the jumper wire also attaches was corroded almost completely off at the battery. All other wires attached to the positive side of the battery were also corroded almost beyond repair. I am not sure if the jumper wire on the alternator was in good shape at the beginning of the season, but I am sure all of the other wires were in excellent shape at the beginning of the season. My volt meter has been showing good charge throughout the season. What could possibly be causing this severe corrosion problem? I did see that the main wire coming from the positive side of the battery directly to the alternator was attached to the house battery and not the cranking battery which seems odd but the batteries are set up in series with the negative terminals attached by the negative terminals. Where do I start looking to solve this problem?
Thanks for your help.
Arthur
Old 11-01-2006, 12:15 PM
Gary Hill Gary Hill is offline
Default Re: Electrical problem
The location of most alternators are to close to the bilge,
Buy a new one or get it rebuilt. while that happens run new wires and verify the engine is gounded to the shaft strutt.
After you get everthing replaced turn the battery switch off and veify on any voltage is present (low volt scale),
then do the samething on the low range ohm scale. If anything shows up, start disconnecting electrical components
till it reads zero. rember complete the volt check first so you don't damage the meter.
GARY
76 SEACRAFT CC INBOARD
Old 11-02-2006, 10:29 AM
Thanks Gary for the information. So you think I have a low voltage drain from a componet because of a bad ground? I will check that out. Where is the best place to buy the new alternator?
Arthur
Old 11-02-2006, 04:08 PM
nestorpr nestorpr is offline
BasicPower.com has some great prices and low/free shipping.
Boatless again!
