Old 12-08-2006, 11:27 AM
oz775 oz775 is offline
Default Dashboard Re-build
I am in the process of rebuilding my dash board area on my 1974 Tsunami- I am going to use black plexi-glass to flush mount my electronics, gauges, etc. I was wondering if anyone has any ideas on how thick the plexiglass should be? Or if anyone has used any othe material to do this modification- any pics are appreciated also. Thanks
1974 Tsunami- 2004 Merc 225 Opti on bracket
Old 12-08-2006, 11:40 AM
Default Re: Dashboard Re-build
If I remember correctly Lexan is much better than plexiglass stronger, not brittle, wound crack, and holds up better. If you do a web search you will learn more that you want to know.
FellowShip
My motto: Just for the Grins
Old 12-08-2006, 12:47 PM
Hey oz......are you planning to modify the basic layout???
I thinking of do it and am trying to come up with the game plan.
Old 12-09-2006, 10:57 AM
i used starboard for mine- the 3/8" was a little flimsey for me , i ended up using 1/2" . Plexiglass is a pain in the ass and will crack like a son of a beech if you aint real careful. The starboard cleans up real nice when wiped down with woody wax occasionally too. these pix are a few years old now and its changed somewhat now but you get the idea- (unless you dont like black)
Old 12-09-2006, 11:15 AM
Oz
If you use Plexi, make sure you back it with a piece of wood before drilling any holes. This will prevent cracking. I used PVC Board and then painted. It cuts, molds and sands like wood
Old 12-09-2006, 11:29 AM
gucci rocks!!!
Old 12-09-2006, 03:07 PM
I was looking at building a module I could add onto th ehelm position....something coming off the top in front of the existing instrument panel at the same angle....going
up high enough to angle down at 45 degrees, then blending into the bottom. It would provide and angled surface to mount the steering and binnacle.
Old 12-10-2006, 11:11 PM
bobbert bobbert is offline
PLEXIGLAS IS NOT A GOOD IDEA. UV AND COMPRESSIVE FORCES WILL CAUSE WHAT IS CALLED CRAZING. (SMALL CRACKS RADIATING FROM THE CENTER OF THE HOLE)
STARBOARD A BETTER OPTION.
BOBBERT
Old 12-12-2006, 02:52 PM
Mine was redone with starboard, very easy to work with.
Old 12-13-2006, 09:56 PM
TUGBOAT TUGBOAT is offline
Made a mold of the old wood/teak dash.Glassed it. I was worried about leakage around the gauges-radio-electronics as I didn't know anything would seal it(Starboard).
Scream'n Reels'
Ever stop to think and forget to start again?
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
