Old 01-30-2007, 03:43 PM
dcobbett dcobbett is offline
Default Steering link arms
Just bought a Teleflex NFB 4.2 system that I need to link to a 2003, 130 HP Yamaha. Is there such a think as a one size/brand fits all steering link arm, or are they sized for particular motors, and what's a good brand/manufacturer, and where should I look before I buy one (eBay prices seem to range between $10 and $15 and on-line stores seem to want $50+/- for brand name units).
Old 01-30-2007, 06:55 PM
BigLew BigLew is offline
Default Re: Steering link arms
Do you mean the cable and the proper end or the linking arm sometimes used when using a fixed pivot point in the steering linkage? Both styles of systems exist. If you are looking for a linking arm, they should be available from most any boat rigger /new boat sales business.
The easier of the two is the direct connect, if the swing distances are adequate, while an inter-link through a fixed pivot point can add some mechanical advantage as well as swing distance.
Remember, the required swing distance increases as the engine connection point is located further from the center of rotation of the engine on its transom mounting bracket.
I realize that this may be confusing, but it can be easily solved by a commercial rigger.
Plan accordingly!
Old 01-30-2007, 07:00 PM
I just realized that you are in Mass. like myself. We could arrange a phone call, if you would like.
Plan accordingly!
