Old 03-07-2007, 11:14 PM
Capt_Mac Capt_Mac is offline
Default 86 Tsunami Transom Rebuild
I'm back!!! I just have to say I would much rather have Hermco do the full transom enclosure with bracketed twins but my x-mas money went to other things that my wife thought were more important(I'm new to this marriage thing). So now i'm going to do the transom rebuild myself and replumb the livewell. I'm going to use 3/4" and then another 1' 1088 board, then add a little more epoxy then what was originally on there. Originally it had 2 3/4" plywood sheets with a lot of grey filler which had some little holes that were holding water. If anybody has any tips or suggestions that would be great. I'll also update with new pictures in the near future.
Old 03-07-2007, 11:54 PM
Default Re: 86 Tsunami Transom Rebuild
So Know body gets confused
http://www.classicseacraft.com/forum...=&Number=41298
Looking good there capt Mac
Old 03-08-2007, 01:55 PM
Does anybody know where to purchase okume or meranti 1088 at in the central florida area? I need 1 3/4"x4'x6' and 1 1"x4'x6'.
Old 03-08-2007, 09:39 PM
Spent pretty much the whole day on the computer and phone talking to people, sounds like I'm doing this backwards. From what I understand I should have taken the inner skin off then put in the core and glass in and work out the right angles which supports the weight and the motion of the motor on the transom. Looking at the pictures, the wood never went down to the bottom and the only thing holding the transom vertical was foam and the grey filler. The foam and grey filler were on all three sides and then you had the fiberglass and core. Will I be okay putting in the core then shot foam and epxoy filler on sides and bottom then glassing the outer skin? or should I cut the angled sides and then angle the core and glass in? Or do some more cutting? Every hole I drill on this boat their is foam. With that said their are no soft spots and the only thing wrong is the transom and some moist foam.
Old 03-09-2007, 09:21 PM
Got some more work done today, the second picture is what my transom use to look like(wood, filler, fiberglass). I also found some 1" cracks on the top of the outer skin where the angle meets the rest of the boat. For mounting the plywood I'm going to glass a traingle foam corner on the three sides after I dig out some of the old foam so that I can attach it easily to the rest of the transom. Then I'll shape the wood accordingly and glass the rest of it in. I'm also going to put 2 knees in the splashwell that will hopefully help with some support. Any other ideas?
Old 03-12-2007, 10:15 PM
These pictures were takin tonight after I put on a layer of glass. Before hand I took out all of the grey filler/putty and I also took about 4 inches inward of foam out that was water logged. Next I will drill a couple of holes and pour foam and allow it to fill in and come out of the holes. Then I will put another layer of glass on the inner skin.
Old 03-15-2007, 09:16 PM
Now I am done with the inner skin except for the knee in the center of the scupper area and the build up on the outside 2 corners of the inner skin. Now where there is an out ward peice of the hull on the last picture, I will bring mat and cloth from the inside then around and attach it to the inside of the inner skin (making a triangle). Then I will bring mat and cloth around from the outisde of the hull and follow the triangle to the inner skin (both sides and the bottom). Next I will pour in the expandable foam and let it dry then cap it. This method allows me to fiberglass the inside of the hull and hopefully add more strength too.
Old 03-18-2007, 03:16 PM
The hole is for the bilge pump along with the saltwater pick that will be plumbed underneath the deck. The hole consist of, going from bottom to top: hull, 2" space, 1/4 fiberglass, 18" of foam(soaking wet), wood enclosed in fiberglass for the deck.
Old 03-22-2007, 09:46 PM
The first piece of marine plywood went on with thicken epoxy over the 1.5 mat that i put on last night. I used a groved trool which I think will help with an even layer through out.
Old 03-22-2007, 11:46 PM
red20 red20 is offline
FYI- most wifes don't like it when you get epoxy all over the driveway , hopefully since you are new at "marriage" she'll let it slide this time.
