Old 03-14-2007, 11:19 PM
peterb peterb is offline
Default Airmar In hull transducers - 600 Watts
I have a Garmin 178C GPS/FF. It will serve as both the backup GPS and FF on my new boat.
I already have one thru-hull installed for the primary FF (a raymarine DS600X) and an unused seacock near it. I plan to use that for either a live well and/or stal water washdown.
I don't want another hole drilled into the bottom of my hull.
This leaves me with either a transom mount or in hull. I would rather not go the transom mount. By default this leads me to the in hull solution.
I see the cheapo 600 watt solution or the expensive 1,000 watt solution. I have read great things about the 1k unit, but is seems a little pricey for me right now for me (at least $600).
Has anyone ever installed the 600 watt in hull in a SeaCraft, and if so, what has your expeience been?
Old 03-15-2007, 06:32 AM
Default Re: Airmar In hull transducers - 600 Watts
Here's the Airmar B-60 w/Furuno 585.....I love it!!
Old 03-15-2007, 09:38 AM
warthog5 warthog5 is offline
Peter, forget about the 1000 watt transducer until you get a serious FF. [Think Furuno]
Without pix's of your planned placement of what you have, it's hard to give you a lot of direction.
We could recommend units to buy, but placement is critical with all the stuff you have now.
The Airmar B60 is a very nice unit.
Old 03-15-2007, 09:55 AM
Warthog5,
Hopefully, I can adequately expalin where I am thinking about putting the in hull ducer.
Right now I have one thru hull to support a raymarine DS600X ff. The thru hull is about 1 foot behind the gas tank, and in front of the closed transom. It is a little off of the keel on the startboard side.
About two feet across from it I have a seacock seup that I plan on using for a livewell.
I was thinking of mounting the in hull somewhere behind the seacock, and in front of the close transom. Hope this helps.
Peter
Old 03-15-2007, 01:40 PM
Peter-Just for kicks, I sank the transom mount ducer that came with my fishfinder(same raymarine you have)into a nice bed of clear lifeseal next to my keel stringer to see how it would operate. The thing gets tremendous resolution and didn't cost me a nickle extra-except for the lifeseal. A lot of the fishing I'm doing requires a good read in dips, humps, and drop-offs and I have been very happy with this set-up-and pleasantly surprised.
Old 03-15-2007, 05:11 PM
Trayder Trayder is offline
Velvet Jones
I have the B60 in the whaler and it is awful in water deeper than 150ft, may just be mine but I am very disappointed with it.
I also did the silicone to the bottom of my transom mount and shove it in the bilge of the Seacraft and it works flawlessly.
Old 03-15-2007, 08:30 PM
Thanks guys. You got me thinking (no small achievement). I will let you know which route I go.
If anyone has any other ideas, please send them my way.
Thanks
Old 03-15-2007, 08:55 PM
I currently have a transom mount tranducer for my ff and the readings are ok while at rest, but really bad at anything over about 12 knots- I've been thinking about a shoot thru hull Airmar for my 21- maybe I'm confused but I though Peter was asking about a shoot thru not a thru hull but most of the advice and pics were for a thru hull- does anybody currently use a shoot thru on a 21 ?
Old 03-15-2007, 09:51 PM
I was asking about a shoot thru.
Pair of jacks,what kind of ff are yout hinking about hooking up the shoot thru to?
I was thinking of giving airmar a call and asking them their opinion
Old 03-15-2007, 11:55 PM
I was looking at the Furuno 585 or the 620- the 585 is bigger (I think 8" vs. 6") and they are both the new digital ff's- I've heard good things about them- I currently have a Furuno ls6000 monochrome from 2000- it works but I'm ready for color and a dual 50/200 unit
