Old 03-30-2007, 08:49 PM
Yamtt125 Yamtt125 is offline
Default opinions...2001 evinrude 150
Hey guys,
I just went and looked at a 2001 evinrude 150. The asking price is $4500. It is being sold from the dealer that origionally sold it. It has 350 hours, and the highest rpm's it has seen is 5120. The computers did not report anythign wrong with it, or any problems in the past.
I was able to get the price down to $4100 and i put a small deposit on it. It also will come with a 30 day warranty.
I'm not concerned with any powerhaed issues that the earlier fichts are known for. My dad has 2 2000 150's, so i know that these engines are good if you have a good one.
My main question is, Is there anything else I should be concerned about?
I believe that the price is good based upon other engines i've seen for sale, and I also checked nada guides.
The engine will go on the back of my 20'. Does anybody have a similar set up? I'm thinkin she'll cruise at 32mph and top out at 45.
Any feedback would be great.
-Andrew
Old 03-31-2007, 09:27 PM
Default Re: opinions...2001 evinrude 150
I had a 1999 150 ficht. Top speed was a hair over 40mph on my 20 MA. My advice is to beat the living piss out of that motor during the first 30 days and get the bugs worked out. That motor needs to be propped to hit 6000rpm . . . 5100 is very very low. Blown the carbon out . . . it probably needs it. http://www.boatsetup.com/Decarb_FICHT.html
Old 04-02-2007, 12:16 AM
Also I think from some good sources on FS you should run the DFI oil from Rude the XD50. Part of the problems on early DI motors was the oil was not as advanced as the motors.
Old 04-02-2007, 08:52 PM
BigShrimpin
There is no doubt that i'll run it at wot for a lil while to get that carbon out...hopefully the previous owner used carbon guard.
Eggsuckindog,
I wouldn't use any other oil except the oil from rude....its not worth using a cheaper oil that is not as good for your engine. Then your just asking for problems.
Any other feedback would be great...thanks
-Andrew
Old 04-02-2007, 10:16 PM
You should do a good decarb on it, since you are from here I will give a number for my best friend and one of the worlds top Rude experts. I just hate to bother him too much but he will answer any question you have on it and will be at our bash and his partner Mario will too with his redone 23- Mike at American Marine 727 938 9796 - tell him I told you call-since he is one of the worlds top Rude experts- a little massage never hurts
www.usavemarine.com is his site also just FYI
Old 04-03-2007, 09:58 AM
There are a variety of decarbonizing chemicals out there, most of them pretty good, although I'm slightly partial to Quicksilver/Mercury PowerTune
One trick I learned was to spray the stuff into the intake while running WOT in gear. Nothing works better except an engine tear-down.
Old 04-03-2007, 01:22 PM
I just bought a bunch of the Yamaha product "combustion engine cleaner" and tried it on the pistons (with the heads off) of a motor that I was tearing down. I tried both side by side and Yamaha Combustion Engine cleaner doesn't hold a candle to powertune. Powertune works much much faster.
Old 04-03-2007, 08:12 PM
Thanks for the replies...i did not think this many people would be familiar with decarbing. I'm not gonna lie guys...i'm not gonna be in any mood to tear the engine apart after all the work i'm doin on the boat. I will consider it next winter though.
I will deffinately decarb it with the instructions via the link previously posted by bigshrimpin.
Thanks for the input.
-Andrew
Old 04-12-2007, 01:27 AM
Just follow the instructions no tear down, the reason I mentioned the X50 is I believe its Direct Injection motor which require different oil than carbs or EFI's.
Old 04-12-2007, 02:31 AM
Just to clear things up here. . . . I was tearing the motor down to part it out. The block had a nice big hole in it. While the heads were off I thought I'd see if there was a difference b/w powertune and Yamaha's Combustion engine cleaner.
