Old 04-05-2007, 08:37 PM
beradtke beradtke is offline
Default merc 175
hello all i have a few questions pertaining to my 1985 175hp merc
1. how much water comes out the pee ( pardon the lack of proper wording) hole on the motor. mine dose not seem to leak alot at idle, but if the motor is raised to 2k it seems to work fine.
2 I changed the lower unit oil is was brown not milky but brown. should i change it a few time to flush it to work out the old oil or change it and just change it in 6 months and be done with it.
Any other suggestiong or advice would be appricated . all i have ever delt with is jon-rudes.
73 seacraft 80 merc my boat
Old 04-05-2007, 09:03 PM
askipper3 askipper3 is offline
Default Re: merc 175
may be a bad impeller or water pump, as long as the engine stays cool you should be good. The lower unit oil.....as long as there is no metal shreads, chunks, etc, than you are ok. (AS far as I know)
1984 Seacraft 20' SF. W/2004 Mercury Saltwater 150
http://i98.photobucket.com/albums/l2...LOGODONE-1.jpg
Old 04-06-2007, 12:27 AM
i have a 1984 200 merc. pretty much the same engine. i have a new water pump in mine and it "pees" like crazy at idle. so you might just need to change the impeller.
Old 04-06-2007, 12:36 AM
beradtke - get a water Pressure gauge hooked up to that motor. There was a good post a while back about the poppet valve on these mercs. The pee issue you see is normal behavior for mercs. Mercs don't pee freely until the cooling system has built enough pressure and the tstats open up. You can monitor this behavior with the water pressure and Temp gauge.
Old 04-06-2007, 08:51 PM
thnaks all off to do some home work on what a poppet valve dose and where it is. might consider putting a water punp in it since i just bought it and dont want to have to repower right away.
Old 04-06-2007, 10:32 PM
Standard yearly maintainance on that motor:
Impeller
Gear oil
Thermostats
Poppet Valve
Plugs
Disassmeble and clean the carbs
New fuel pump kit.
New Inline filter
New Fuel water Seperator
Decarb every 100 hours
Inspect all wiring and bleeder holes
Check for leaks around hydraulic Trim + Tilt rams
I also recommend running w/o Spark Advance Module/idle stabilizer and with timing set manually. Dump the Oil Injection and premix. The oil injection on those motors is notorious for failing. I have two bad cranks in my garage from motors with busted plastic gears.
I'm sure I'm leaving something out . . . but that's all I can think of now.
Old 04-07-2007, 10:42 AM
the oil injection was off on mine when i got it. my neighbor around the corner has a 165 merc with 1 bad cylinder and im thinking its from the oil injection...
Old 04-08-2007, 08:23 PM
no oil injection been removed
the idle stablizer is still on it why remove it? just being courious?
poppet valves are very intresting in what they do. i read a article formn about a year ago that someone had a put in what they do and how the water circluates ion the head.
Old 04-09-2007, 01:35 AM
Here's a link that pretty much sums it up.
http://forums.screamandfly.com/forum...=spark+advance
or for more info just do search on this forum.
