Old 04-05-2007, 09:38 PM
osprey osprey is offline
Default b-60 transducer
Hi folks! I did a search on this ducer and didn't find an answer to my question. I have an 89 23cc. Up in the front locker, the drain is through an inner and outer layer with foam core. In the bilge toward the stern,I'm wondering if it is cored also. All the pictures of other installs show no coring. Just wonder if all years are like that. The installation is different if there is a core. Want to get as much info before I go and cut a hole in the bottom. Thanks
Old 04-06-2007, 09:18 AM
Default Re: b-60 transducer
My '73 23' is solid 5/8" glass. Pucker factor was high when drilling the hole!! There's a picture here of the install if you search.
Old 04-07-2007, 05:23 PM
Cut the hole yesterday. My hull is only 3/8 thick in the bilge.No core. Now I know the difference between the tracker hull and the potter hull. With the tracker hull, you can only hit small rocks.
