Old 04-30-2007, 10:43 PM
stoney stoney is offline
Default Shake down cruise gone bad
The shake down cruise in the Chesapeake went very bad when the submerged log hit the lower unit. It broke off the splash guard for lack of a better term. See attached. Has anyone successfully repaired anything like this?
http://i15.photobucket.com/albums/a3.../001640480.jpg
73 23 SF 2004 200 HP Yami OX66 Best boat I owned!
2002 29 Seavee twin 200 yami's
Old 04-30-2007, 11:26 PM
gw204 gw204 is offline
Default Re: Shake down cruise gone bad
I've used the gray Marine Tex on lower units before. I bet you could build it back up with that stuff.
Brian
1981 Mako 17
Old 04-30-2007, 11:51 PM
Trayder Trayder is offline
Velvet Jones
take it to a welder/fabricator and they will have it like new in no time.
Sorry to hear this happened on your first trip out.
Old 05-01-2007, 12:48 AM
Ditto on what Trayder says. It's not even expensive. I had the back 4" of the cavitation plate of my wife's old 115 fabricated and welded after being struck by a car and it cost only $130 a couple of years ago..
Old 05-01-2007, 10:17 AM
jongolds jongolds is offline
A welder is definitely the way to go. I've had to get skegs welded a couple fo times. It makes it a little easier on them if you can give them a tracing of what it should like like when done. If you can find another motor with the same leg, just trace the area back to a good reference point, like the back of the leg so that he know how big and what shape the piece he needs to weld on should be.
1973 23' Tsunami, 300hp Etec
Norwalk, CT
Old 05-01-2007, 01:43 PM
As mentioned should be no problem and it doesn't bear much pressure
Old 05-01-2007, 07:14 PM
MMikeB MMikeB is offline
It was a bad day but it could have bean a lot worse, you could have got to inside the casing. This is an easy fix for a welder that heliarcs aluminum. Basically someone that makes fuel tanks could take care of this.
Old 05-01-2007, 08:56 PM
Finster Finster is offline
I wouldn't loose a lot of sleep over it, it's not going to hurt performance. The cavitation plate is above the water when your running. Though cosmetically......
Thats much better than a whole lot of other nasties that could of happened.
http://lecharters.com
'76 23 SC CC I/O
'86 20 Aquasport 200
There's more but w/e
