Old 05-12-2007, 12:41 AM
pfrench pfrench is offline
Default Where is the plug located on a 23 Sceptre?
More dumb questions; On the 23 Sceptre where is the plug? I cant figure it out. Also Its an I/O if that makes a difference.
Old 05-12-2007, 01:48 AM
Default Re: Where is the plug located on a 23 Sceptre?
mo then likly inz the loose hoze u donut nose
wher whatz it fer.
sam
Old 05-12-2007, 01:56 AM
I just need to know what compartment to look in for the drain plug, if you can be helpful please. Thanks in advance.
Old 05-12-2007, 02:31 AM
If there is not a rubber plug on the lower end on the back of the transom, there should be a threaded brass Garland plug.
Take an adjustable wrench and remove the plug.
Ken
Old 05-12-2007, 09:09 AM
Thanks Bones, so I should look on the transom near the bottom?
Old 05-12-2007, 09:15 AM
Yes....on the transom near the bottom of the V....usually a slight amount to one side because of the keel on the inside.
By slight I mean a couple of inches.
