Old 05-31-2007, 09:10 AM
stoney stoney is offline
Default motor height and nameplate
I rebuilt the transom at 25" to match the motor and put the motor back in the old holes. It now occurs to me the motor might be a couple inches low. Any opinions? What motor heights have you used successfully?
Also my 73 23SF does not have numbers molded into the hull. the only nameplate is what you see here. Is anyone aware of the legitimate way to transfer hull numbers?
73 23 SF 2004 200 HP Yami OX66 Best boat I owned!
2002 29 Seavee twin 200 yami's
Old 05-31-2007, 09:15 AM
bunderwood bunderwood is offline
Default Re: motor height and nameplate
I know the cavitation plate needs to be even or a little higher than the lowest part of the hull....It looks like its a little low to me!
Old 05-31-2007, 10:00 AM
LEVERETTE5 LEVERETTE5 is offline
Hey stoney can you tell me what size prop your running and RMP at WOT.I have the same boat and motor as you.Any info would be great.Thanks Keith
Old 05-31-2007, 06:22 PM
The outer edges of your cavitation plate should be just slightly above the bottom of the hull in front of them, so that no part of the plate extends below the hull.
Old 06-01-2007, 01:44 AM
warthog5 warthog5 is offline
Looks like it needs to move up 3 holes. Each hole will move it up 3/4in.
