Old 05-31-2007, 03:55 PM
EagleOCNJ EagleOCNJ is offline
Default Help with transom mount transducer placement
I finally got my boat in the water with a new look after a year long makeover.
I dropped it in started 'em up no problem and idled a few minutes then worked my way up to about 35 knots.
I looked back and saw water blasting off of my motor and up in the air. I shot a rooster tail of like 20 feet! Damn it - it was my transducer. I determined that it is mounted a bit too low 1/2 inch below the boat) and may be in a bad spot? I mounted it low in hope that Id get a reading from it a speeds.
The first ducer is at the bottom point of the V with the garboard plug - this one works good. The second ducer is on the port side. Where should it be in relation to the chines/strakes or whatever they are called.
I am bummed out that I have to yank the boat again and fix the ducer at the ramp tommorrow. I need help before I waste my time and get it wrong again.
Old 05-31-2007, 04:21 PM
JW-Tex JW-Tex is offline
Default Re: Help with transom mount transducer placement
I have always heard to mount on the starboard side-the water is suppose to be cleaner (assuming the motor is not a counter rotator).
No advice on how far to have it below the hull, mine is mounted inside the hull in a pvc pipe with cap submerged in mineral oil.
Old 05-31-2007, 06:20 PM
Mount in so that the bottom of the 'ducer is 1/8" below the hull, with a slight angle forward. I recommend just inside of the inner hard chine, so that at higher speeds it will still get a reading.
Note, however, that at speeds above 35 mph, even the bottom hard chine can catch air. When my Humminbird Matrix does that, I don't get a good reading again until I slow down below about 22-23 mph.
A shoot-thru hull transducer avoids that issue, but then you gotta put in faring blocks to get it vertical and all kinds of other stuff.
Old 06-01-2007, 01:51 AM
warthog5 warthog5 is offline
Yep. A 1/8in below at the transom and a 1/4in below at the aft end of the ducer. [Slight tilt looking forward]
I should also be on the STB side. Every instruction sheet that comes with a ducer tells you that.
Old 06-02-2007, 07:43 AM
I did it no problem and no more rooster. Thanks- now my lights and some elects dont work. Geez!
Old 06-04-2007, 11:48 AM
John.. I had the same problem with mine even after I did the same things. I really bugged me to have the water blowing of the motor. So I made up a little spray shield that I mounted right next to the trans.. stopped the problem and didn't effect the transducer.
Don Battin
Pipe Dreams Marine
"Design her right,
Build’er well
Bend the throttles,
And let’er eat…."
Carl Moesly
Old 06-06-2007, 03:42 AM
Don,
It ended up being no big deal; yes a PITA but a couple hrs at Tenn Ave and back in. No more rooster.
