Old 06-04-2007, 04:54 PM
dudley dudley is offline
Default Tsunami 23 inboard changed to 225 suziki outboard.
Some seacraft owners might be interested in my modification.Replaced 350 gm inboard, tunnel hull 23ft,r with 30"suz.225.Cut transom at29" to top of tunnel.Test ran and had no cavatation. She runs nice and flat. Had to change prop. only turned 4600, I used to be a seacraft dealer when they started. Great boat.
Old 06-04-2007, 06:18 PM
joema joema is offline
Default Re: Tsunami 23 inboard changed to 225 suziki outboard.
I raised my transom to a30 on a septer running a df 250 5800 with a16 20 prop try a 16 18.5
Old 06-04-2007, 09:18 PM
MarkR MarkR is offline
On a bracket or the orignal transom?
Why go to a $12,000 outboard and not stick with the $5,000 inboard power plant?
Old 06-14-2007, 08:30 PM
Used the original transom for this mod.I reinforced the transom with plywood lots of mat roving and a knee.My basis for such a radical change was lack of room on deck.Now the boat is open and perfect for fishing.I catch large blue fin tuna,well sometime.
Old 06-14-2007, 10:25 PM
red20 red20 is offline
cooper -- post some pictures, I thought it would be cool to do and add a jack plate.
Old 06-26-2007, 08:39 PM
Will try to post some pic,s. Real busy at present. Believe a jack device might work well on the tunnel. I will try raising the engine this fall.
