Old 06-26-2007, 11:13 PM
pawill2 pawill2 is offline
Default Mercury 200 EFI water pressure problem.
I have a water pressure gauge and the water pressure jumps up and down alot. I have replaced the water impeller and housing. Any thoughts?
Old 06-27-2007, 12:11 AM
Default Re: Mercury 200 EFI water pressure problem.
Remove the tube and blow air through it. More than likey a piece of trash lodged in that tiny tubing.
Also did you replace the pop-it valve???
Ken
Old 06-27-2007, 11:24 AM
The pressure will vary between idling and running at cruising speed. My Optimax runs 3-4 psi at idle and 12-14 psi at cruising speed. Does the motor over heat? Also check thermostats.
Old 06-27-2007, 10:09 PM
Mine is all over too no problem
Old 06-27-2007, 11:50 PM
You need 7-8 lbs at cruise, and 3 lbs at idle at a minimum.
