Old 07-08-2007, 08:24 PM
thedink9 thedink9 is offline
Default Trim / tilt unit troubleshooting help 250 YAMAHA
My trim/ tilt unit quit yesterday after i trimmed up to go over a sand bar. Some basic troubleshooting revealed the up/ down relay is clicking and the big honker 80 amp fuses look ok.
Is there any other troubleshooting I can do? Perhaps another fuse in line that I am overlooking or some kind of a shutoff low oil relay or something else to check before I go out and have to buy a new trim motor? Thanks in advance for your input. Dink
Old 07-08-2007, 08:54 PM
bunderwood bunderwood is offline
Default Re: Trim / tilt unit troubleshooting help 250 YAMAHA
Mine did that a couple of months ago and all it was was a relay 15.00 item the one that is clicking is the one that is bad! Hope that helps...
Old 07-08-2007, 10:39 PM
bku
Can you tell me where he relay is located? I heard the clicks when i pressed the trim switch but couldn't locate it. It sounded like it was near the big fuse panel but wasn't obvious to me.
Old 07-09-2007, 08:39 AM
mine is a 88 merc 150 there are 2 relays to the right of the carbs if your on the ground facing the motor.
