Old 07-12-2007, 09:12 PM
vcs vcs is offline
Default tachometer stopped working
I have a 1988 Johnson 150 VRO. I replaced the tach with a new one, still not working. I have traced the grey signal wire back to the engine and used an ohm meter to check for continuity. Any suggestions would be greatly appreciated.
Tony
Old 07-13-2007, 12:40 AM
Default Re: tachometer stopped working
check to see if your charging system is working,if not you will need to ck resistance on voltage reg. and stator but
prob. voltage reg.
