Old 08-03-2007, 03:08 AM
vcs vcs is offline
Default prop size
I have a 1976 18 sf with a 1988 johnson 150. I currently have a 14.5 x 17 pitch prop on it, it is only running 5200rpm wot. I was told to go with either a 15 x 19 or 15 x 21 prop any suggestions.
Tony
Old 08-03-2007, 02:29 PM
Default Re: prop size
You were told wrong! If you want more rpm, you need LESS diameter or pitch, or raise motor 1 hole (cavitation plate can be about 1" above bottom of boat if you run a cupped prop). I tried 14.5 x 19 and 14.25 x 17 stainless props; the 17" pitch prop picked up 200-300 rpm. Currently running a 14 1/8 x 20 4 blade SS, but it's a little too much for heavy load. Am considering having Bobby Soles cut it down some. He's a good source of prop info and also sells used props.
leave it the way it is.. Your only 300rpm off what it should be. With a motor that old and your only 300 off .. your doing fine..
Don Battin
Pipe Dreams Marine
"Design her right,
Build’er well
Bend the throttles,
And let’er eat…."
Carl Moesly
Old 08-16-2007, 08:49 PM
76Red18 76Red18 is offline
I HAVE AN 18 WITH A 99 150, T TOP , 15 X 19 STAINLESS, 42MPH @5500
J. M. Hendrix
