Old 08-13-2007, 08:31 AM
BigLew BigLew is offline
Default ?? \"Hydro Foils\" on Outdrives on Scepters
I am looking for opinions on using hydrofoils, a.k.a. Doelfins, on outdrive units on 23'Scepters.
My thinking is this. 900-1200 lbs. of engine and drive at the stern coupled with about 1100 lbs. of fuel in the 140 +/= gal. belly tank. If we can get a few hundred pounds of lift from such fins, are they worth the effort and what are the trade offs. Trim tabs then become more of a tool to balance the load port/starbord and since they needed to be extended less- reduced drag.
I would be interested in the thoughts of those members that have considered/investigated such things.
Thanks in advance for your contributions.
Plan accordingly!
Old 08-13-2007, 10:17 AM
JohnB JohnB is offline
Default Re: ?? \"Hydro Foils\" on Outdrives on Scepters
If your talking about an outboard setup, a 4 blade powertech prop give you quite a bit of lift, but you give up just a little on the top end. Trim tabs also can help, so can moving everything that can moved forward. I found between the old battery mounting pads in the back bilge, wet wood in the transom and fuel platform, etc, I was able to shave off a couple hundred pounds. I have used Doelfins on smaller boats, was never a fan of them on big boats.
JohnB / 23' SeaCraft
Old 08-14-2007, 08:02 AM
First of all, Doelfins will work on sterndrives, just as they do on outboards. They only create an appreciable drag when the drives are trimmed all the way down.
Second, in a chop, they are very good at keeping the bow down cutting into the chop for a smoother ride, and they cost less than trim tabs.
However, unlike trim tabs, they cannot be used independantly of the drive angle. This means that underway and planing, you cannot adjust the boat's attitude while maintaining the best thrust angle on your outdrives. Remember that the best outdrive thrust angle while underway on a plane is as close as possible to parallel to your direction of travel, given the detractions of ride quality and trim angle. For thhis purpose, trim tabs are much better.
Given cost considerations, I'd probably go with the Doelfin or Stingray hyrdofoil stabilizers. You WILL get on plane faster, and be able to plane at a slower speed.
I have a Merc 150 OB on a Seafari 20, and I have a Stingray XPRIII mounted to my cavitation plate, AND a stabilizer mounted to my skeg.
I plane in under 3 seconds, and have a top speed of nearly 50mph. It looks funky, but works well.
Old 08-14-2007, 10:17 AM
Fr. Frank,
I was hoping you'd chime in!! Understand I have a V/P 260 I/O on my 23' Scepter.
I actually have both a Doelfin and tabs. You make a point about maintaining the cutting angle in a chop and I do appreciate that benefit as well.
I'd like your thoughts on the following point. Does the Doelfin, etc. generate any lift like a hydro-foil and if they do, would that "lift" (I'm thinking maybe a few hundred pounds worth) reduce the amount of trim tab extension needed to maintain optimal trim of the boat. My thinking is that the lift possibly generated by the Doelfin comes at a lower cost, in terms of drag, than the same amount of "stern" lift generated by trim tabs?
Any thoughts? I look forward to hearing back from you and anyone else with thoughts on the subject.
Plan accordingly!
Old 08-14-2007, 12:06 PM
The overall drag to achieve a given effect will be about the same regardless of where you create that drag - at the lower unit with a hydrofoil stabilizer or at the transom with trim tabs. The difference is in effective thrust based upon the angle of that thrust to the direction of travel. the closer to parallel to your intended direction of travel the more effective thrust.
This is why outboards and sterndrives with power-adjustable trim on the drives are so much more efficient than most straight inboards. They can produce thrust very nearly parallel to travel, where an inboard is usually pushing at 8 to 15 degrees out of parallel in a downward vector.
The most efficient thrust system available is a trim adjustable surface-piercing drive, because you don't have the power loss from going through 2 90 degree directions changes and a u-joint. All you have is the u-joint.
That being said, there are 2 times you want that stern-lifting thrust at the rear of your boat: getting on plane, and keeping the bow down in rougher water.
Old 08-14-2007, 04:25 PM
Fr Frank......what kind of stabilizer is on your skeg...
I'd be interested in seeing a shot of that setup.
Old 08-14-2007, 07:10 PM
I spoke with Fr. Frank this morning. Boy, that guy has forgotten more than we all know put togther!!Well, maybe not that much, but he's just as nice a guy as you could ever imagine.
I'LL SAVE HIM THE TROUBLE. I looked up the website and here it is:
http://www.hydro-shield.com/
Plan accordingly!
Old 08-14-2007, 11:37 PM
That's Lew.....
I have a heavy WAC boat (6000lbs) with an I/O Bravo 1 that I think could benefit from having a stabilizer fin...whether above or below the prop. It's a rounded keel boat and the handling at low speed is squirrely due to bow steering.....I think these would help. I also think they'd help it stay on plane better. It has tabs but there smaller ones.
Old 08-15-2007, 06:48 AM
BigLew has it... I have a Hydroshield on both my Seafari AND my Carolina skiff. They work very well. Here's a photo of a small one. Unlike most hydrofoil stabilizers, these work even when you're trimmed up, and at are in the full flow of water past your boat even at high speed.
Old 08-15-2007, 11:49 AM
Just some further thoughts, experiences, with fins -
My last boat was a 25" Bayliner Cierra, a pretty big tub, about 5000 lbs, always loaded with weekend sleepover gear, cooking gear, etc; powered by an older, carbed, points ignition, chevy 350, on a Volvo IO outdrive. When I had the whole family together, and the kids were bigger, it was an absolute slug out of the hole.
I had a doelfin installed, and this made a world of difference. Instead of plowing thru the water, trying desperately to climb up out of the hole, now the back end just popped right up, and she got on plane quite quickly.
This boat had Bennet trim tabs, and maybe I didn't really know how to use them to best effect, but adding the doelfin really made a major improvement.
just my observations, re big boat / hydrofoil effectiveness.
Bill
