Old 08-31-2007, 07:59 AM
JimC JimC is offline
Default Inboards
85 23' cc straight shaft inboard; in the process of repowering, rewiring and redoing console; would appreciate any pictures with ideas and suggestions -- would like to eliminate having to flip entire t-top to access engine -- also suggestions for locating fuel vents -- previous owner had them outboard mounted which allowed water intrusion
thanks -- jim
Old 08-31-2007, 08:56 AM
Default Re: Inboards
if you search inboards there is plenty of info and pictures- Chance has a lot of pictures, I do too with wiring and other stuff- my fuel vents might be in the same place as yours , i dont know but i havnt had any problems with water intrusion to my knowledge.
2006 update and work
Old 08-31-2007, 10:14 AM
Jim,
I have same exact boat and did the same thing 2 seasons ago. I have the stock console and have engine access from a wooden access panel on the back of the console & a front seat that flips up on the front of the console. I have also cut in 2 inspection hatches on the front of the console for easier access to the top of the motor. I also had inpection hatches cut into the deck for easy access to change the plugs etc... To do any major work the T-Top does flip all the way forward for complete engine access.
Old 08-31-2007, 10:38 AM
jongolds jongolds is offline
I dont' have any expertise in this but I think you'd want to keep the fuel vents outboard. Otherwise, I'd be worried about venting fuel vapors and the occasional burp during fill-ups in to the cockpit.
1973 23' Tsunami, 300hp Etec
Norwalk, CT
Old 08-31-2007, 10:54 AM
Gary Hill Gary Hill is offline
The fuel vents on mine are factory installed facing aft slighty downward. Working on most motor issues are pretty easy with the shelf lifting up to expose the motor
GARY
76 SEACRAFT CC INBOARD
