Old 08-31-2007, 12:04 PM
david76 david76 is offline
Default motor and gas
ok allu xperts i need some help here i have a evinrude xp 150 vro the vro is notactive anymore i just had the gas tank acid washed on the inside. Now when i am cutting across the lake at a good speed my motor shuts down and my ball sucks dry.Now if i loosen up the hose clamp it goes back to normal pump the ball again and im off and running. So i could really use some help here thanks.
Old 08-31-2007, 12:09 PM
JohnB JohnB is offline
Default Re: motor and gas
Anti-siphon valve stuck/clogged or clogged tank vent.
My guess is they loosened some junk up, and it's the anti-siphon valve.
JohnB / 23' SeaCraft
Old 08-31-2007, 12:21 PM
so am i suppose to just keep running it or do i go buy a new tank, i hate going across the lake and BAM i lose my fuel.
Old 08-31-2007, 01:14 PM
Pull the anti-siphon valve out and throw it in the trash. It is a check valve in the bottom of the fuel pickup tube. One thing I know for sure, if that is what it is, it will do it again and again . As long as the fuel line and carbs/efi are higher than the top of the tank, you don't need it.
Old 08-31-2007, 03:22 PM
there is no anti siphon and its a carb. engine 1990 model
im thinking of selling the boat and get something smaller i dont know the hull is in such great shape and i just got the transom rebuilt im having a breakdown H E L P!!!!!!
Old 08-31-2007, 03:51 PM
Yo . . . Young1 - The problem isn't the motor. The check valve/anti-siphon valve is on your fuel tank . . . NOT on your MOtta. They go to sh1t all the time.
If you don't have a check valve on the tank . . . then your vent (on the TANK) is blocked.
I replaced my check valve with a regular 3/8" brass nipple . . . but the check valve provides you with some level of saftey if you're motor caught fire. Fire will supposedly only burn back to the check valve.
Old 08-31-2007, 04:34 PM
Right-On Tim!
Since he lives in Fl and by chance his SeaCraft has been sitting around, I'll betcha one of those Mud Dobber Wasps built a nest in the vent line
BTW: You need to keep the "O-Ring" on the fuel fill cap lubricated. The gas will dry it out and crack. Then every time you wash you boat or it rains, guess what enters the fuel tank
Old 09-02-2007, 11:13 AM
well i have decided to pull the tank and put a new one in i ran on the xternal all day yesterdayand she ran like a champ.
Old 09-02-2007, 12:11 PM
Uh . . . my car ran out of gas . . . I think I'm going to the dealer to buy a new car
Old 09-02-2007, 02:58 PM
funny ha ha not funny queer!!!!!!!!!!!!!!!!!!!!!!
