Old 11-02-2007, 09:57 AM
Happi1fla Happi1fla is offline
Default Cracked Stringers
Finally getting back to it , Thanks Alex , and everyone
on sharing your pic's and info, Was able to get the
tank holder out, surprisingly easy by prying up with a 2 X 4
But Surprisingly I've got big problems , A crack in two
locations.
1st up front where the stringers start/ near the anchor locker theirs an inspection hole that was once cut, it has
a lengthy gouge on the outside of the boat also.
2nd crack is just into/below the tank holder a foot or so.
Question with these cracks , Is their a correct way to get
to the bottom of each stringer, (any pic's) Maybe removing
the top skin, and digging out the foam,
also any suggestions on toughening up what is cracked, material use, epoxy, poly resin any compound,
will go the long way around to fix this if I have too.
stressed , Thanks everyone.
John
[image]ttp://i215.photobucket.com/albums/cc314/Happi1fla/leftsideundertankholderslip.jpg[/image]
