Old 11-02-2007, 10:47 AM
Default Materials
Hey guys well Im hoping to start my project within the next couple of months. Was wandering if someone could give me an idea of how much material i will need to redo the deck and transom of my 79 20 SF. Planninng on using marine ply, so how many sheets? How much resin/cloth? I want to start buynig the material now so I can have it ready to go! Thanks in advance for the help!
Old 11-02-2007, 05:56 PM
Default Re: Materials
if you need some help with that project let me know!
Old 11-02-2007, 08:54 PM
Thanks Im sure I will whats up with you and that other boat...Is yours going now?
Old 11-02-2007, 11:49 PM
well the 23 is just not in the cards right now. i sent u a PM about mine a few weeks ago. i guess u didnt get it? for ur project i would use epoxy. its gonna cost more but from my project its easier to use.
Old 11-03-2007, 12:22 AM
i been doing some research and finding that they say the polyester is easier to work with??
Old 11-03-2007, 08:57 AM
WillyC WillyC is offline
I redid the transom on my 20' sf. I started with one six gallon kit of epoxy from raka. That should get you through the transom for sure. You will probably need two kits if your doing the floor too. I have enjoyed working with the epoxy and wouldn't want to have to deal with the fumes of polyester resins. I have found the raka epoxy to be great stuff and much less expensive than other brands. -will
Old 11-03-2007, 11:41 AM
doug7488 doug7488 is offline
clean up polyester resin w/ acetone
clean up epoxy w/ vinegar
the choice is yours
Old 11-03-2007, 01:45 PM
will - thanks for the info...how much plywood did you use?
Old 11-03-2007, 10:26 PM
Tarpun Tarpun is offline
i didn't know vinegar removes epoxy. That by itself is a reason to use it instead of polyester. Epoxy is stronger and bonds better.
Tarpun
1972 20 Seafari
1977 23 Savage
1980 20'Master Angler
Old 11-04-2007, 12:57 PM
I didn't use plywood for the transom. I used one 4' x 8' sheet of coosa board that was 1 1/2 inch thick. I did use one sheet of plywood to recore all of my hatches. I think it was 7/16" non treated. For the transom you will need two sheets of 3/4 inch plywood - at least that is what a majority of people use. As for the floor, I dont know. You will have to take a couple of measurements to determine what you will need. -will
