Old 11-21-2007, 10:54 AM
askipper3 askipper3 is offline
Default MPG or GPH
I need to find just how much Gallons I burn.
Either in MPG or GPH. Either is good.
I have a 84' 20SF w/ 2004 150 Merc. 2-stoke Carb.
Does anyone have a "rough" estimate- or is their an easy way to find out?
1984 Seacraft 20' SF. W/2004 Mercury Saltwater 150
http://i98.photobucket.com/albums/l2...LOGODONE-1.jpg
Old 11-21-2007, 11:26 AM
Default Re: MPG or GPH
Maybe fill the tank, run for an hour. Log your GPS.
Fill the tank again. Note your load and speed as it will vary depending on all that as well as wind and tide.
Or buy a Flo scan....
See ya, Ken
Old 11-21-2007, 12:18 PM
JohnB JohnB is offline
Flo scan is the way to go. It will pay for itself in 20 trips or less. You can change the trim/rpm/tabs on the boat to get the most economical speed based on load in the boat and sea conditions. If I run mine at 4400 rpm, I am at about 30 mph getting 1.6 mpg, if I bump it back to 3800, I run about 26 mph, but get close to 2 mpg. On an average trip, I run 100 miles, the difference is over 12 gallons, at 4 bucks a gallon, thats 48 dollars, by just slowing down 4 mph or so.
JohnB / 23' SeaCraft
Old 11-21-2007, 03:36 PM
peterb peterb is offline
Like JohnB said, once you have a device that gives you realtime feedback it's amazing how the little things add up (such as tweaking the tabs and finding the optimal speed range, which may be different than the engines suggest).
With my boat the RPM's and MPH speed are pretty close to one another (except at the top range when I am going 57 MPH at 5,300 RPM's).
I have twin Yamaha 0X66's and average between 1.6 and 1.8 Mles per gallon when cruising. If I bump the engines to above 4,200 RPM's the engines purr like kittens but start to swill the gas. I would not have not known this if it weren't for the fuel mgmt. system.
Old 11-21-2007, 07:58 PM
3rdday 3rdday is offline
take a 1,2 0r 5 gallon reserve tank. Drop your fuel line into that and run it dry. Use a GPS to log your miles.
You can try a 1 tank on cruise, another on WOT, etc.
Old 11-24-2007, 09:43 PM
Get a fuel flow meter, really. I run a '92 Merc 150 carb, on a 20' Seafari and I improved my overall fuel economy by over 50% with my Navman.
Old 11-26-2007, 07:17 PM
Navman?
Old 11-26-2007, 07:47 PM
76Red18 76Red18 is offline
Navman?
Fr. Frank, I was looking at the Northstar Fuel 310 system. Uses GPS data to calculate mileage. Around $350. What do you think?
J. M. Hendrix
Old 11-26-2007, 07:56 PM
Not sure but i thought Northstar took over?
http://cgi.ebay.com/ebaymotors/ws/eB...NA:MOTORS:1123
or this;
http://www.byownerelectronics.com/st...e.php?cat=1546
Or this;
http://www.byownerelectronics.com/st...at=2996&page=1
Old 11-26-2007, 08:12 PM
That second item looks like the unit I'm looking at
J. M. Hendrix
