Old 12-09-2007, 02:44 PM
76Red18 76Red18 is offline
Default Gear Oil vs Lower Unit Oil
Changing water pump and oil in my 99 Johnson 150. Is it ok to use castrol 80-90 hypoid gear oil? I have a 5 gal. bucket full. Thanks in advance for your comments.........Richard
J. M. Hendrix
Old 12-09-2007, 04:08 PM
JohnB JohnB is offline
Default Re: Gear Oil vs Lower Unit Oil
My first choice would be Amsoil synthetic marine, and my second choice would be prem. Merc lower unit oil. The additives in these will mantain lubrication and corrosion resistance if water gets inside. Straight gear oil is ok as long as water doesn't get inside.
JohnB / 23' SeaCraft
Old 12-09-2007, 04:56 PM
Never know when you'll get intrusion, so AMS it shall be! Looks like a good product, got some on order, costs only a buck and a half more per quart than the penzoil I've used previously. Whats your thoughts on the pre-mix 100 to 1? I use Johnson/Evinrude red type @ 50 to 1 with very little smoke and carbon build up; I think the carbon gaurd additive I use keeps the build up in check. I just wonder about that high ratio....Richard
J. M. Hendrix
Old 12-21-2007, 10:16 PM
gss036 gss036 is offline
Just my personal opinion, but I would stick w/50-1 mix. I run Penziol Prem synthetic blend in my 200 hp Merc.
Gary
