Old 01-04-2008, 10:41 PM
Default Scupper Question
Has anyone ever used these scupper drains. Was thinking they would work to replace the scupper in the seacrafts and avoid using plugs? [image]http://i134.photobucket.com/albums/q83/bkufire98/scupper.jpg?t=1199496769[/image]
Old 01-04-2008, 10:42 PM
Default Re: Scupper Question
Hmmm ok cant get the picture to work???
Old 01-04-2008, 10:45 PM
http://i134.photobucket.com/albums/q...98/scupper.jpg
Old 01-04-2008, 10:48 PM
Here is the product description:
Cast bronze with rubber check ball. Comes complete with key. For use when discharge is below waterline.
Angle of outlet is 45 degrees.
Screw size is #8.
Available in 2 sizes:
1" hose with 3 1/4" flange
1 1/2" hose with 3 3/4" flanges
Old 01-04-2008, 11:45 PM
3rdday 3rdday is offline
I do not like this type of scupper. They only work well when the deck and drain tube exiting the hull is well above the waterline. You will be walking in a swimming pool, you will have to get the boat on plane to evacuate. been in lots of flats boats with them. The ball seems to always float to top sealing the oriface. I prefer the horizontal style that have ping pong ball in them with silicone diphragm. They mount outside the transom you can also push the ball into the diphragm and it will work like a plug. These will work well even if your drain holes are on the waterline or very close or even well above.
Old 01-05-2008, 12:42 AM
what caught my eye was this-----For use when discharge is below waterline------I do not plan on raising the deck its going back to the original height/level! Thanks for the input thought they might work!
Old 01-05-2008, 01:06 AM
pcfishslayer pcfishslayer is offline
Where did you find this scupper? I like that one better than what I already bought.
Old 01-05-2008, 01:19 AM
www.discountmarinesupplies.com -its a pretty good website. I bought some flush mount cleats 316 stainless for 35.00 each and stainless flush mount nav. light for 79.00 prices seem to be pretty good! that scupper is 69.00 each
