Old 01-11-2008, 12:03 AM
downeast25 downeast25 is offline
Default 350HP crusader in a 23 inboard.......
would anybody know the cruise numbers on a rig like this ? boat is a 23 inboard with a 350HP crusader . thanks
Old 01-11-2008, 12:51 AM
3rdday 3rdday is offline
Default Re: 350HP crusader in a 23 inboard.......
Just curious and to clarify; is that a 350 HP or Cubic Inch?
Would also depend on prop dia. and pitch.
Old 01-11-2008, 07:37 AM
ericminnig ericminnig is offline
i get 24knots at 2700rpm 29 knots at 3200rpm
Old 01-11-2008, 09:29 AM
Probably both Cu in and HP....
Old 01-11-2008, 10:44 AM
Nexgen is your boat an IO not an inboard, I have never heard numbers anywhere close to yours?
I get a 20-22 knot cruise at 3200-3400 running the same power package. This is with a large T-Top and a good amount of fuel.
Old 01-11-2008, 01:16 PM
thanks for the replys everybody...yes it is 350ci 350HP straight inboard. riprunner whats your fuel burn at that speed ? i fugured it would be a little quicker with this package
Old 01-11-2008, 04:10 PM
my boat is an inboard 350ci 350 hp 17" wheel
Old 01-11-2008, 04:32 PM
I was hoping it would be quicker too, it's really the only negative I have with the boat. I started with a 15x17 wheel and based on suggestions here and original specs moved to a 16x17 wheel and a got the same exact numbers with a little bit more vibration. At that speed I burn about 10-10.5 GPH on the smartcraft gauge. My numbers are pretty close to everyone else with inboards that I have talked with even though I push more HP than most. I also have a very tall hard T-Top with enclosure and usually run the boat heavy on fuel so that does effect my numbers slightly.
Nexgen, do you have a t-top, bottom paint etc...? What are you doing to get those fantastic numbers?
Old 01-11-2008, 04:40 PM
sorry my prop is 16x19 it a sceptre i get on average 10 gal an hour yes it has bottom paint. thoose numbers are with people and some fuel too.
Old 01-11-2008, 05:42 PM
interesting . i can live with your #s..lol are you sure they are in knots and not mph ? anyway i have seen big diffrences in 2 inches of pitch . 350HP is a lot of HP for a 23 footer i would say . thought for sure it would get routinely 23+ on a cruise around 3100rpms
