Old 01-16-2008, 10:35 PM
pcfishslayer pcfishslayer is offline
Default Another Prop ?
I just bought a 2000 Yamaha Salt Water Series II. I will be putting it on my 76 20ft SF when I am finished with it. It has a 14x17 prop. Is this the optimal prop? Does anyone have a good guess what kind performance I might get with that or suggestions on a better prop.
Thanks for any help.
Old 01-24-2008, 03:30 PM
Default Re: Another Prop ?
HP needed, althouth you will to run it first to get an RPM at max to determine which size.
Old 02-20-2008, 07:24 PM
I did forget to mention it is a 150 hp. I hope to have it in the water by March 14th.
Old 02-21-2008, 01:53 AM
17 will probably be perfect
Old 02-21-2008, 06:10 PM
Thank you
Old 03-07-2008, 08:07 AM
gordonhg gordonhg is offline
I have a 115 E-tec running a 15p on my 20 CC, seems just about right for my boat. I also think the 17p will be a good fit for your boat with the 150hp.
Old 03-13-2008, 03:24 PM
I think you'll be somewhere in the in mid 40's with a 17 pitch. Just depends on how fast that motor will spin the prop. You want to make sure you prop that motor so it can turn at least 5500rpm at WOT. Also . . . make sure that the cavitation plate lines up about an 1" or 2" above the bottom of your hull. That makes a big difference in LU drag and the props ability to ventilate.
http://www.go-fast.com/Prop_Slip_Calculator.htm
