Old 03-17-2008, 05:38 PM
datngrizz datngrizz is offline
Default Painting Hull
Folks - I am a new SC Owner of a 1980 20 MA. I am just getting started on the repairs. What is the best way to support the boat while work is underway ? It is currently on a trailer. I am concerned about painting/patching around either method where they contact the boat and want to know the easiest way to approach. Best way to access/paint these areas while in work. I see some folks using 4 boat screw jack stands (right term?)and others setting on bunks. Where do I get these stands if that is the way to go? Thanks!
DaTNGrizz
Old 03-17-2008, 06:40 PM
76Red18 76Red18 is offline
Default Re: Painting Hull
I used blocks of 8" x 8" wood pylings with 2" styrofoam between the block and the hull. 2 on each side to prevent tipping and 3 down the keel. concrete blocks are alright as long as you place them with the "cell" in a vertical position with a piece of ply wood between the block and styrofoam. A block on it's side or end has very little compressive strength. 7 supports might sound like over-kill, but it makes it easier to change their position once the bulk of the hull is painted. As far as the screw jacks are concerned most of the ones available are for stability not weight support and probably pricey to rent. Blocks are about $1.75 each and a sheet of 2" foam is $15 at your local home center. Whatever you decide to do make sure that the ground your working on is level and well compacted.
J. M. Hendrix
Old 03-17-2008, 10:00 PM
About the painting...paint the hull..move the braces...cut in where the braces were? Is there a "Right"way? THX!
DaTNGrizz
Old 03-17-2008, 10:39 PM
DaTNGrizz
Thats what I did. Wet sand the edges before you paint where the supports were, then wet sand those edges again after painting for a smooth finish. I think I used 600 grit. Wax paper between the styrofoam and new paint wouldn't hurt. It almost wanted to stick together.
J. M. Hendrix
Old 03-18-2008, 08:03 AM
Good plan. I like the wax paper tip. THX!
